*Starter wont't run
-Fuse burned out
-Weak battery
-Faulty ignition switch
-Faulty starter switch
-Faulty front or rear stop switch
-Faulty starter relay
-Poorly connected, broken or shorted wire
-Faulty starter motor
*Lack of power
-Weak battery
-Loose or bare wire or connection
-Foreign matter stuck in starter or starter gear
*Engine does not crank-starter rotates
-Faulty starter pionion
-Reverse rotation of starter
-Low battery
STARTING SYSTEM TROUBLESHOOTING
Moderator: FAQ Moderator
