1. 24mm x 1.0 RH MAG Puller "Make sure it has threads on the outside of the tool"
http://www.repairmanual.com/catalog/DS-MP43 -This tool will work-
2. Adjustable wrench of some sort. I used channel locks.
Lets get started!.
Hand tighten Mag Puller into flywheel
Hold the outer side of the Mag Puller with the wrench
Use a ratchet to drive the push bolt | I swapped out the Allen style bolt with a 9/16 bolt from home depot -- Start cranking
You'll hear a large popping sound, like you've snapped a bolt. Now you can remove the flywheel by hand.
Remove the stator if your going to be splitting the case.
Grab a beer your done.
