HID Lights on a spree.
Most people, including myself, want better lights on their sprees.
Here is a mod for a 1986 spree headlight
Now I know this light takes more power than the stock light, but not too bad on a nicely charged stock battery.
However I would not recomend this much light for any scooter, as I am pretty sure that it is not legal in any state.
This HID kit is rated at 10k in brightness and is a H11 style bulb
This is the STOCK HIGH BEAM on a 1986 honda spree
This is the H11 10k HID bulb in the Stock housing.
Tools required for this mod are:
Magicstick
cardboard (thin)
Sharpie marker
1 US nickel
Spreetard
Re: HID Lights on a spree.
Post by Spreetard »
A simple three-step guide to illegal lighting. :twisted:
now to work out a low beam...
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
dem0nk1d
Post by dem0nk1d »
Defacing more currency I see. :naughty:
is that silver peace behind the plug the nickle? oh that tail light got shipped out yesterday btw.
"Like I tell people all the time Speed cost money ..if you have to ask how much then most times your not going to do it !" -tru72
--\\\Projects\\--
95 Elite Restore Project for Wife
1982 Honda Passport
2013 Honda PCX 150
odinxxix
Post by odinxxix »
where did you get the bulb? i like how the looks, low beak could just get a lower watt lite.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
odinxxix wrote:where did you get the bulb? i like how the looks, low beak could just get a lower watt lite.
It is a kit for a car with a ballast and eveything. Only uses half the kit, so find a buddy to chip in on a kit. they are about $80 for the kit and about $25 for replacement bulbs (for 2 bulbs)
The stock headlight runs off of AC current, so to do this conversion , you need wiring right from the battery and about 12 awg wire and a switch (I used the stock headlight swicth and a relay. High beams = on low beams = off)
Also note that the stock light consumes 1 amp of current. The HID setup uses 3 amp of current when in use and up to 7 amps to start up
These are REAL HIDs There is no filliment in the bulb, only gas that glows Very bright when you put 20kv to it. :smile:
dem0nk1d wrote:Defacing more currency I see. :naughty:
The nickle is for measuring and template making. It seems I will have to explain this in more detail :hi:
Use the Magicstick to cut the old bulb out of the sealed beam housing
Now the opening should be about the size of a nickel. Remember to shake out all the broken glass from the original bulb.
Get a piece of thin carboard to make a template from the bulb. I used a sharpie to mark it all out.
Thanks - nice work and for the detail pics - will move to Technical Docs.
2 questions - What's a Magicstick?
Is the inner bulb envelope intact in this mod?
odinxxix
Post by odinxxix »
that is a great setup!! but at 80 a pop WOW!!!. i wonder though and i know it was talked about once before somewhere but why couldnt we do the same with a regular automotive bulb with a filiment. is it because of the more the 25w the stock one uses? i have a couple here that are like 55W. im sure there is a 25-30W somewhere out there.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
odinxxix wrote:that is a great setup!! but at 80 a pop WOW!!!. i wonder though and i know it was talked about once before somewhere but why couldnt we do the same with a regular automotive bulb with a filiment. is it because of the more the 25w the stock one uses? i have a couple here that are like 55W. im sure there is a 25-30W somewhere out there.
Yeah $80 might seem like alot but that is for a pair. If two people want this kit, I will split up another kit :smile:
You can use a regular automotive light bulb. And those should be about $5. I just chose the H11 cause I had them. I did a different one with a H3.
I got the mounting harware from a broken fog light
novs86
Post by novs86 »
Cool idea!
Nice job Jamz!
I'd rather be riding my Aero!
mousewheels wrote:Thanks - nice work and for the detail pics - will move to Technical Docs.
A # 1:This is the Magicstick
A # 2:the stock dual filliment bulb gets destroyed.
odinxxix
Post by odinxxix »
T-jamz on the second one with the fog lamp,did you also use the direct batt power and the switch or will it run off the power like stock?
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
odinxxix wrote:T-jamz on the second one with the fog lamp,did you also use the direct batt power and the switch or will it run off the power like stock?
The H3 bulb has the base grounded for a DC only setup. So that one still would need direct battery 12v and a switch.
But a non HID H11 could run on the stock wiring (AC circiut)
HID Light testing (the flash was turned off for these tests)
Pic 1 my garage lights on
pic 2 lights off stock headlight
pic 3 lights off HID headlight
dem0nk1d
Post by dem0nk1d »
that same bit you used for the porting on your engine case, correct? if so i'm going to get that bit for sure.
--\\\Projects\\--
1982 Honda Passport
2013 Honda PCX 150
