Yes, PG Long is sitting next to me waitingz50r-blank wrote:Mr. evilone,
wow dude, nice job - your motor looks great!-that's what i love to see; complete, accurate, clean builds!
keep us posted on your build, and post up progress pictures. Are you using the PG Long you bought from me on that build?
elite_dub couldn't help you out on a mini-stroker crank? Either way, you will be happy w' the stock crank. Veedubh20 swears by the stock crank's strength and ability to handle higher modified engine RPM's. -You can't argue w' Honda reliability
snow, snow, snow here. im ready for Spring.![]()
later, jon
Uh-Oh!The mini-stroker elite_dub was trying to get me was discontinued
No problem, thanks for looking. My cast iron Malossi 72cc is ported pretty good, I ran an R1 last summer and i'm sure the PG Long will open it up alot. I dropped from a 28mm oko to a 24mm oko per arnadanoobs advice. I think i'll be right where i want performance wise. I was almost to that point using the low-rev R1 and 28mm carb. I'll keep my eye out for a stuffer crank to use later if needed.elite_dub wrote:wish I could of found you a crank man, they are floating around, but people just don't want to let them go...I know sanjuro sourced his from Japan and cost a pretty penny also.. a stock crank will work out great just get some porting done on whatever kit your putting in there.. I did just find a lower price on the SEF copy crank from Travis where Jon received some of his parts but he's still asking $200... there are the run of the mill ruima half counterweighted crank they work great but I know that stuffed crank gives you best of both worlds a faster rev along with the case pressure of a full countered crank without the weightGOOD STUFF
Have fun with your build and good looking out on that tool.. I may buy one soon, just to have and it works alot more simpler than the OEM Honda tools
Hopefully as more of use start modding the parts will stay availableWheelman-111 wrote:Greetings:
Quoth EvilOne:Uh-Oh!The mini-stroker elite_dub was trying to get me was discontinuedWe may be seeing more of that as the years since the AF series was last produced pile up.
