86 spree acceleration issues
I was recently given a spree. When I got it it would top out at around 17-19mph. Now however it will only top out at around 12-14 and that is only downhill. The motor sounds like it is stuttering and when top speed is achieved the motor sounds like it is going to come apart its clanging so bad. I know nothing about these type of engines and would very much like some help. I am going to look at the drive belt and clutch today to see if those are the culprits. How do I make certain that the part is bad before I replace it? Anyone else have any other ideas?
Re: 86 spree acceleration issues
man that sounds like my spree but mine will still go 30mphbut it make all the noise your talking about.i'm going for rebiuld
im thinking a rebuild is in your immenint future, sounds like it could be engine bearings IE connecting rod. is there oil in the oil tank under the seat? check the plug it could be really bad fouled. to see if your clutch is bad pull the kick start cover and remove both front and rear pulley. the clutch bell is in the rear. if the pads are half missing or real thin time to replace. i suggest downloading the manual from here http://www.hondaspree.net/phpBB3/viewto ... ?f=11&t=37
this will give you the specs. good luck and keep us posted. oh and welcome.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
Thank you for replies. I am printing the entire manual as we speak. Geesh its huge. I will check the clutch when I get home as well as a few other things and Yes I will keep you posted. Once again thank you.
Can I start my scooter when I take the kick start housing off to see if thats where the noise is coming from?
not recomended.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
You could put an impact wrench on the crank nut and spin it to start, but first remove the Bendix before attempting this.
