What is a Pod filter?
- bigbuickgs
I guess that is it. What is a pod filter. I have a chrome v-8 breather with a piece of 1-1/4 heater hose to connect it to the carb. I havent put it on yet because with when I was trying things out I discovered that the engine just dies when you hit the gas w/o the stock air box. What size main jet should I start out with to try this.
- burnt_toast
these are unifilters:
http://www.unifilter.com/clamp-on.htm
and pod filters are gauge wire filters, like K&N's.
projects galore
Guys that claim to have gotten it to work usually run #80 - #90 jets.
Totally. It has to do with the design of the airbox. I've been so unimpressed by them I've quit messing with them for a time. If you can connect a piece of hose to the carb, lengthening the intake tract, it helps the scoot draw air better at lower RPM. The airbox volume helps the scoot draw air better at a variety of RPMs, rather than just being optimized for one.
Yeah, I think at that point you can actually use the airflow. Either way, you'd be running a larger carb that won't fit the stock airbox tube. I wonder, though, if you created a larger tube to the stock airbox and opened up those little airbox inlets by the same amount you bumped up the carb, if you wouldn't get a better running scoot that could run with a smaller main jet.
Some guys have posted positive results with stock displacements and pods, though, so I haven't completely written them off.
- bitteraspects
- hrnytrtlsgsxr
- hrnytrtlsgsxr
- bitteraspects
hahahah. why eould you say that???hrnytrtlsgsxr wrote:then you could get them at VT I presume.bitteraspects wrote:kuka makes tubes with the oversized lip opening to fit on a bigger carb.
but yes, they used to carry it, i believe there are still some there. i used one to adapt my stock sym dio50 airbox to a 28 oko carb
