no good, broken head bolt
Posted: Wed Oct 19, 2005 12:13 am
by Mormonmopedmaifa
welll i got my new head gasket and stuff and set it all up then i was puttin the head back on i was putitn on the bolts and torquin em. and one broke ...... at 8 lbs....yes i am sure it was lbs. but neways how do get this broken piece of bolt out of their. im not gonna buy a new engine.i want to fix this one up. i spent 150 on the whole ped so im not spendin tons on it. il just go buy an elite if it comes to that.but neways how would i go about gettin those bolt peices out?
Posted: Wed Oct 19, 2005 6:55 am
by darat
well if it just snaped at the top then u can take out the other bolts and get some plylers and back it out.
Posted: Wed Oct 19, 2005 10:22 am
by Mormonmopedmaifa
no its down in there so i cant grab it with pliers.
Posted: Wed Oct 19, 2005 12:51 pm
by noiseguy
If it's snapped off clean at the surface of the block, remove the head/jug and buy an "Easy Out." Go to the hardware store, they'll know what it is. Take the dimension of the bolt you need extracted with you. Look at the side of the Easy Out, it will list a drill bit. If you don't have the right size at home, buy it too while you're there. Then follow the instructions. Put rags in the case to keep out metal shavings. You're looking at about $10 in tools.
I would suggest that you get a metric tap to clean out the remaining holes, or at least clean and oil the bolts before tightening in the future. Sounds like you have some corrosion in the block.
Posted: Wed Oct 19, 2005 2:22 pm
by Mormonmopedmaifa
well im noso sre it actually was at 7. the torque wrench just kept reading 7 as i tightened it. it never wnet up
soo i think the culprit might be the torque wrench(never usin that one again)o well soo how do i do this. i drill a hole in the bolt thats inside? how much would it cost to get a shop to do it?
Posted: Wed Oct 19, 2005 2:29 pm
by vette76
Mormonmopedmaifa wrote:well im noso sre it actually was at 7. the torque wrench just kept reading 7 as i tightened it. it never wnet up
you drill out the center of the bolt, and use the easy out. i strongly recommend a punch so u drill it dead center. u dont wanna hit the threads.
Posted: Wed Oct 19, 2005 2:31 pm
by Mormonmopedmaifa
and what is a punch???????im pretty good with tools and fixin mechanical stuff but i dont know that much about these engines and stuff( i just need to find out how it all works )o well thanks
Posted: Wed Oct 19, 2005 2:37 pm
by vette76
a punch is a tool u hit with a hammer, and it makes a small dent in the metal. so the bit doesnt "walk"
Posted: Fri Oct 21, 2005 3:38 pm
by Mormonmopedmaifa
how hard is this to do and would it be a good idea just to take it to a shop?
Posted: Fri Oct 21, 2005 4:15 pm
by vette76
it is kinda a pain in the *. come to think of it, these bolts aernt hardened are they?
Posted: Fri Oct 21, 2005 4:19 pm
by Mormonmopedmaifa
I have no clue... how much would it cost to get a shop tp do it?
Posted: Fri Oct 21, 2005 4:21 pm
by vette76
i dont know about a shop. take somthing sharp and try and scratch the bolt. if it doesnt scratch its hardened, and u cant drill it.
Posted: Fri Oct 21, 2005 7:45 pm
by eager_beaver1
drill it maybe
Posted: Sat Oct 22, 2005 12:22 am
by maddog
If you snap a head bolt stud it will not go into the case! sooo! what seems to be the problem! :wink:
