spree problem
Stan371f
spree problem
Post by Stan371f »
Newbie here...Ive got a 86 Spree that ran fine until last year then died. It would start without the help of starting fluid but die soon after. I know its not good to use the starting fluid. So what I have done is put a new plug in, new carb that is clean and new filter. Also new fuel lines and filter. Seems to have same problem of not wanting to start without assistance. When it starts it runs for maybe 10-15 sec then dies. When I give it throttle, its like it wants to stumble and the dies. Any suggestions? Any help would be great! Thanks
Your carb isn't clean. Check your idle circuit. You can't see light through it.
Admin, Hondaspree.net
Mormonmopedmaifa
Post by Mormonmopedmaifa »
i think the idle jet curves... im not sure but i thin it does. i had t clea mine and i just straightneded out a safety pin and stuck it through the hole where the throttle cable normally comes in and put it in the little hole then stuck sum needle nses through the air intake hole and pushed em down. and i had to use a lot of force but now i can see a reaaaaaal tiny dot of light through it.
vette76
Post by vette76 »
ur not really supposed to use a pin. it can damage the carb
87' spree (SOLD
12' wrx
Mormonmopedmaifa
i just jammed it down the tiny hole next to the main jet( that is the idle jet right.... i never really got an answer but heard people sayin " long tube next to main)
Don't use a steel tool to clean the idle jet, you'll damage it.
Mormonmopedmaifa
too late now lol . o well im gone get a new carb soon neways being as ,my current one is jb welded together. i was also wondering , when my friend screwed the long mounting screw in the wrong side it kinda presed up against the choke area and i was wondering if that might have toasted it. ( i cant pull the little brass CYLINDER out , the cylinder around the pin is what im talking about).
