Page 1 of 2
im doing 38 mph with stock gears
Posted: Sat Feb 27, 2010 4:15 am
by ae86guy
when i first got the bike it did 25mph so it got pulled apart now with new bearings the taz 44mm bbk some porting on exhaust port and some porting under the reeds and intake pipe 90 main jet and a pod filter no pully mods got it doing a strong 31mph but i had to back off the throttle a bit at wot because it bogged a bit.So today i welded up my new expanshion chamber exhaust now it screems up to 38mph on a hand held gps at wot i dont need to back off now at all the speedo says im goin faster than 38 but i beleive the gps more .The power band didnt kick in to about 31mph and it was pretty boggey under that did a few cut and welds got it down to 25mph then ran out of welding wire damm it i will finish the exhaust during the week thought id give the neihbours a rest it sounds like a motocross bike now AWESOME i have some taz gears coming ill see how they go might get a bigger tyre as well it may need a push off at the lights with everything on but thats ok so long as i can smoke those damm chinese bikes everyone rides now i will get some pics up as soon as i work out how to i tryed to shrink some pics i had but it said they were to big ill work it out MAN I LOVE THIS GAME-- :peace: (SEE HOW FAST I CAN MAKE A NIFTY FIFTY (SPREE) :worship: :rock: :worship:
Re: im doing 38 mph with stock gears
Posted: Sat Feb 27, 2010 12:09 pm
by bradthreee
Nice work so far :thumbsup:
Keep an eye out for odinxxx's gear install coming soon to a thread near you.
There also seems to be some trouble with the gears as they are making whirling/grinding noises in 2 installs so far. I would wait to see how those people figure out the problem before you make it #3
Posted: Sat Feb 27, 2010 12:47 pm
by fightingplankton
and word on the street is videonut is working on a variator for the nq50... :naughty:
Posted: Sat Feb 27, 2010 2:24 pm
by devenex
Awesome! You should post some pics of the pipe. Did you document making it at all? If so post that shizzle!
Posted: Sat Feb 27, 2010 3:37 pm
by evilone
fightingplankton wrote:and word on the street is videonut is working on a variator for the nq50... :naughty:
I thought taz was, or are they both?
Posted: Sat Feb 27, 2010 4:24 pm
by ae86guy
taz is working on them as well ive been emailing him about them ive got that problem with the whiring rear gears now and i havent got the taz gears yet i was hopeing that they would fix it
Posted: Sat Feb 27, 2010 5:58 pm
by odinxxix
ill post some pics of the install a little later. taz suggest removing the washer behind the clutch gear said it worked for him but it made it louder for me. it just feels as if there is a wee bit too much backlash in the gears. noway to fix that since we cant move the gears left and right. i thought maybe after a little while in the oil they will quite down but its too cold here to run them around. maybe next week when we have that 40 degree day ill get a chance.
Posted: Sat Feb 27, 2010 8:33 pm
by fightingplankton
i was joking, it was a reference to http://www.hondaspree.net/phpBB3/viewto ... ee#p106519
didnt know about taz's til just now.
Posted: Sun Feb 28, 2010 4:36 am
by tazland001
I installed a set of the gears on one of the spree's before I sold it and it was a bit un-smooth in the * end. So I took the washer out and it was smooth as silk. Maybe in your case you might want to try to add another very thin washer and see if that helps. It is funny they are all the same scooters but different sometimes. Just trying to help. I have sold over 100 sets of gears and I have had no complaints about a whirling sound. Keep me posted.
Taz
Posted: Sun Feb 28, 2010 11:17 am
by odinxxix
taz its nothing against you man, but like you said they are the same yet different. wheelman suggest that the spaceing may be bad due to not haveing a gasket(honda has discontinued them). the noise has seemed to lessen a little since i redid the rear end so maybe it has something to do with the spaceing.
Posted: Sun Feb 28, 2010 1:36 pm
by ae86guy
mine has the wine now and i havent installed taz gears yet i tryed spaceing the gears in and out and took out the locators for the trans cover and shifted it around a bit i made it better while on the stand but it came back after a ride or to my rear wheel has a small buckle in it i thought that was the cause just trying to get another wheel now
Posted: Sun Feb 28, 2010 2:33 pm
by odinxxix
the backlash i refer to, its like an up and down,if you grab the tire and slightly like to spin it forward and backward you hear the gears knock, its not an in/out slop.
Posted: Mon Mar 01, 2010 2:22 pm
by elitedio
Yeah I like it, a bit of science and math and you get a lot more out of your two stroke. I don't like hearing about you having to push off from a stop. At that point you probably have lost the race.
Good job so far.
Posted: Mon Mar 01, 2010 4:00 pm
by tazland001
I did not know honda does not carry a rear gasket for the gears. I should get some made for me. they might sell. Did you check your bearings? Maybe there a bit of slpo in them? just curious.. I did not have that problem with the gears. They where smooth for me after I removed the washer. How many miles are on your spree?
taz
Posted: Mon Mar 01, 2010 5:32 pm
by odinxxix
i have 7240.8 but it all looks new inside the case im going to try adding some washers and see what happens.
