My Honda Elite...what needs to change(?)
cpimp
Post by cpimp »
To put it simply, my little urban stallion just isn't running like she should. I got a new air filter today as i had taken out the old shards of foam that were in there a few weeks ago. So now its quiter and slightly slower again...do I really need that filter!!?!?
And the thing has almost no throttle response sometimes. Half the time I twist the throttle halfway and a second later it starts to kick in and putt along.
And I think my speedometer is off, which would mean I'm barely making it to 32mph.
BUT! I am gonna go to my buddies house right now and drill out the stupid muffler. Hopefully it works out alright.
deathwish
Post by deathwish »
clean ur carb should solve alot of that
Wanna kno how to keep an idiot busy for hours look below
Wanna kno how to keep an idiot busy for hours look above
cpimp
Post by cpimp »
can i use carb cleaner from kragen and just put that in the gas tank?? And thanks for all the help!
FastSpree1
Post by FastSpree1 »
if i were you i wouldnt do that. two reasons you could fry the piston. seriously ive done it before and what a mess. and 2 it still wouldnt clean it near as well as cleaning it with sone pipe cleaners that things like that. i would buy a can of areosol carb cleaner to clean it once you take it apart.
deathwish
Post by deathwish »
i have never really tired it but i would sujest just taking it of and giving it a good cleaning!!!!!! but i have no clue about the carb cleaner in the tank any one else???? :roll:
FastSpree1
im tellin ya its a really bad idea. i put a tiny capful in every tank to keep it clean but putting more that that in your tank will do major damage. but after you clean it id put a tiny cap full of it in every tank it seems to help keep it clean
vette76
Post by vette76 »
i wouldnt put ant in the tank at all. i have never heard of doing this. hav u ever seen what carb cleaner does to plastic/rubber? well there are a few parts in the carb that can be destroyed. and never mind what it might do to the piston/cylinder. what im trying to say is. DONT DO IT! clean it the old fashioned way.
87' spree (SOLD
12' wrx
Some guy's swear by Seafoam, which is an in-fuel cleaner. Thing to keep in mind is that these "cleaners" are meant for larger tanks. With a total capacity of .5 gallons, you need to be careful how much you put in a scoot.
But the Honda carb is so basic, just 2 jets, and is easy to remove. Take it off and clean it manually, it will do a better job anyway.
Admin, Hondaspree.net
...shards of foam? Did your engine ingest the old filter? If so, you will want to inspect your reeds for debris/damage. They may not be closing now.
cpimp
Post by cpimp »
I still dont understand how I do it manually. I get aersol and carb cleaner and i then somehow shoot it through the carb?? I'm not even sure how that would work.
Remove the carb, take the bowl off, and clean the jets... read the manual for details. You don't even need to remove the float.
maddog
Post by maddog »
After you clean the carb take the trans cover off, on the back of the front pulley you will see a restictor ring held on with 3 nuts take it off and you gain more speed, also check roller weights for flat spots, ramp guides for play, belt for wear, clutch pads and the 2 pins that ride the s-groove in the rear pulley.
burnt_toast
Post by burnt_toast »
vette76 wrote:i wouldnt put ant in the tank at all. i have never heard of doing this. hav u ever seen what carb cleaner does to plastic/rubber? well there are a few parts in the carb that can be destroyed. and never mind what it might do to the piston/cylinder. what im trying to say is. DONT DO IT! clean it the old fashioned way.
yeh that is a horrible idea. if needed, take apart and clean, don't try to cheat.
projects galore :nerd:
darat
Post by darat »
what kind of elite is it?
cpimp
Post by cpimp »
its an 87 elite 50cc
