elite manual
-aL-
elite manual
Post by -aL- »
there should be some elite manuals in the tech docs... i feel left out
I need to get over to Derek's and borrow them... are you around this Sunday?
-aL-
thnx
Post by -aL- »
it would be a big help to me thanks
We'll see if I hear back. In the meantime, the Aero 50 manual is pretty close.
gman75
Post by gman75 »
I could use an elite manual too. for the '89 SB50 elite...
Greg
Scooter-less
NQ50 (Spree) and SB50 (Elite 50) should have nearly (if not exactly) identical motors. If you find differences, I'd be interested in hearing what they are.
vette76
Post by vette76 »
cases are a little different. (crank case covers are not interchangeable)
carb is a little different. (oiler injector is in carb as opposed to the intake tract.)
drive pulley is a little bigger in the sb.
87' spree (SOLD
12' wrx
gman75
Post by gman75 »
Is that an improvement that the elite pulley is bigger than the spree's?
Scooter-less
I don't think the larger SB50 pulley will fit, based on description. You can get quite a bit out of the larger over-the-counter Spree part, with .10" milled from the face and a larger belt (which loses some ratio but helps the clutch work better.)
vette76
Post by vette76 »
no, it will not fit in the spree cases.
87' spree (SOLD
12' wrx
