well soon im gonna try and retract that broke bolt and i was thinknin anyhting that needs done inside the engine i miht s well get done while its open. so i was thinkin ... how would i replace the rings around the piston i think i need new ones really bad. also how do i put em on and take em off? are there any things i need to be careful about when installing these things?
and how is the easiest way to do it they dont look like theyre easy to take off or put on.
Rings
- Mormonmopedmaifa
Rings
M>M<M
THE MAFIA STRIKES AGAIN!!!
ALMOST running spree!!!
- burnt_toast
make sure that you can tell which ring goes on top, and which one goes on bottom. they're slightly different.
as far as taking them off, you can get a ring tool, but its pretty easy to just use your hands. Just start from one side, and slowly work around it till it pops off.
I also recommend a hone after you get new rings, to help them seat right.
projects galore
- Mormonmopedmaifa
