wire
808stalion
wire
Post by 808stalion »
who ever has a 85 spree where does that green wire thats coming from the frame by the brake light connect to?
702 ISLAND BOYZ DA RIO DIO
Re: wire
Eight-Oh-Eight, can't be positive about your Spree but solid green goes to Ground on every other Honda I've seen. Under any handy frame bolt should be fine. Mouse?
odinxxix
Re: wire
Post by odinxxix »
is it just plain green or green with a black stripe? just green is a ground. green with bl stripe is the wire coming off the resistor.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
fightingplankton
Re: wire
Post by fightingplankton »
this topic was discussed in the "blown headlight" thread.
its your ground. it connects to the frame from....everywhere
'86 spree
'86 aero50
'83 aero80
808stalion
Re: wire
i no its a ground so does it connect to the green with black stripe that is on the wire harness ? and for the back blinkers i see a light blue wire and a orange wire i no thats for the blinkers but is there supposed to be a ground that goes with it cuz i dont see one i never used back blinkers on my other sprees before and trying to hook that up .
Re: wire
808stalion wrote:i no its a ground so does it connect to the green with black stripe that is on the wire harness ?
The responders are all correct. Bunch of smart folks there :thumbwink:
Green - no stripe is frame ground. Green/Black stripe is to the resistor side of the bystarter. Given the bystarter's other end is tied to AC from the Stator Headlight coil, hooking the taillight ground would impact taillight brightness, and bystarter warm up.
Here are marked up schematics:
Green Wire connection:
Green/Black wire:
fightingplankton
Re: wire
your rear turn signals do not have a ground "wire." they use the metal from the rear rack which is bolted to the frame as ground.
if you've omitted your rack, simply run a wire from your signals to the nearest ground you can find.
the orange wire is the positive for both front and rear left turn signals(blue is for the right side).
if you look on the front, the front signals have 2 wires each, one is blue and green the other is orange and green.
both green wires plug into the main ground, the other 2 go to the respective positives.
basically the ground goes from battery (-) to everything else at some point.
hope that helps.
'86 spree
'86 aero50
'83 aero80
808stalion
Re: wire
ok thanks everybody thats all i wanted to no cuz i no i seen the main ground wire for the front blinkers but for the back i did not see anything so if the groung is build into the rear rack all i need to connect is to the wire harness is the orange,light blue, for the blinkers and brown,green,and green with yellow stripe for the brake right but will mess with it today and see what happens
fightingplankton
Re: wire
808stalion wrote:all i need to connect is to the wire harness is the orange,light blue, for the blinkers and brown,green,and green with yellow stripe for the brake
yep you got it. but like i said, if you're not using the rack, you'll need to ground the turn signals another way.
'86 spree
'86 aero50
'83 aero80
LawlerClan
Re: wire
Post by LawlerClan »
I had the same question. PO removed the rack and I wound up with one extra ground wire.
808stalion
Re: wire
just went put all new bulbs and still nothing i using the rack and still nothing working not even my lights by the gauges is turning on this is iratating could it be cuz my batt is close to dead ? but when i turn the key on my gas gauge moves
fightingplankton
Re: wire
if your bike starts, and is running, your lights should be running off the alternator not the battery. okay, your fuel gauge is on because it runs from the battery to the ignition then to gauge via black and green wires there is a y/w wire that runs to the sensor.
w/o seeing whats going on, i dont know what else to tell you.
hmmm.
check your turn signal relay.
if thats not it...make sure your turn signal switch is wired up properly
one more question to help diagnostics... do the front signals work?
Last edited by fightingplankton on Tue Mar 09, 2010 2:38 pm, edited 1 time in total.
'86 spree
'86 aero50
'83 aero80
fightingplankton
Re: wire
also, can we move this thread to the tech help section for future readers?
'86 spree
'86 aero50
'83 aero80
808stalion
Re: wire
ya can move em but back to the front blinkers no it does not work to but i just put in a h4 bulb for my headlights and now thats working fine wal mart 10 dollars
fightingplankton
Re: wire
then my bet is on your blinker relay.
like i said. check the switch too.
'86 spree
'86 aero50
'83 aero80
