fired up after winter, bell ring sound.
94cruiser
Post by 94cruiser »
Hello.
Today I installed the battery, and poured in fuel.
When I started up the scoot I heard a bell sound that went away after a while.
What is it?
Bike runs the same as before wintertime.
(I had it partially disassembled, kickstart and the side covers.
I also found a little round hollow cylinder made out of metal when I started it. Any ideas what it's for?
:rock:
2000 Elite SA50
stock
odinxxix
Re: fired up after winter, bell ring sound.
Post by odinxxix »
ok lets see here, you had the kick cover off,did you do anything to it? that little metal hollow tube might be the spacer that goes in the variator which also might explain the bell sound.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
94cruiser
Post by 94cruiser »
here is the photo with the cover off (taken with my phone)
in the center of this pic you can see the hollow roller in the center.
2000 Elite SA50
stock
odinxxix
Post by odinxxix »
yea that looks like the spacer the goes in the vari, it goes inside the lg hole then the lg gear goes on. if it is not in place damage could accur
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
94cruiser
Post by 94cruiser »
I was planning on riding it from my parent's garage to my house about 10 miles but I'll skip that.
I wonder how the heck this thing came out?
The day I drained gas when the scoot was leaned to one side I would hear marble noises which I thought were the rollers, but maybe it was this.
2000 Elite SA50
stock
Bandit240
Post by Bandit240 »
Thats way too small to be the centre of the vari. It looks more like one of the little collars that go between the engine case and the belt cover case where the bolts go through.
1986 Honda Elite 150 Deluxe
1991 Yamaha XT600
1993 Honda Elite 80
2001 Honda Elite 50
94cruiser
Post by 94cruiser »
bandit,
can this go through where the two cases meet in the middle?
:imo:
2000 Elite SA50
stock
bakaracer
Post by bakaracer »
That is a dowel pin guide for the trans cover.Those things come out pretty easy sometimes.the ringing sound is because the rear trans is touching the rear pulley from that missing guide so the cover is sitting out of place.You can run without that rear cover.It won't hurt anything.In fact is better for the rear clutch in keeping in cool.
