fired up after winter, bell ring sound.
Posted: Wed Mar 17, 2010 7:48 pm
by 94cruiser
Hello.
Today I installed the battery, and poured in fuel.
When I started up the scoot I heard a bell sound that went away after a while.
What is it?
Bike runs the same as before wintertime.
(I had it partially disassembled, kickstart and the side covers.
I also found a little round hollow cylinder made out of metal when I started it. Any ideas what it's for?
:rock:
Re: fired up after winter, bell ring sound.
Posted: Wed Mar 17, 2010 7:53 pm
by odinxxix
ok lets see here, you had the kick cover off,did you do anything to it? that little metal hollow tube might be the spacer that goes in the variator which also might explain the bell sound.
Posted: Wed Mar 17, 2010 8:08 pm
by 94cruiser
here is the photo with the cover off (taken with my phone)
in the center of this pic you can see the hollow roller in the center.
Posted: Wed Mar 17, 2010 8:45 pm
by odinxxix
yea that looks like the spacer the goes in the vari, it goes inside the lg hole then the lg gear goes on. if it is not in place damage could accur
Posted: Wed Mar 17, 2010 10:19 pm
by 94cruiser
I was planning on riding it from my parent's garage to my house about 10 miles but I'll skip that.
I wonder how the heck this thing came out?
The day I drained gas when the scoot was leaned to one side I would hear marble noises which I thought were the rollers, but maybe it was this.
Posted: Wed Mar 17, 2010 10:23 pm
by Bandit240
Thats way too small to be the centre of the vari. It looks more like one of the little collars that go between the engine case and the belt cover case where the bolts go through.
Posted: Wed Mar 17, 2010 10:43 pm
by 94cruiser
bandit,
can this go through where the two cases meet in the middle?
:imo:
Posted: Thu Mar 18, 2010 12:56 am
by bakaracer
That is a dowel pin guide for the trans cover.Those things come out pretty easy sometimes.the ringing sound is because the rear trans is touching the rear pulley from that missing guide so the cover is sitting out of place.You can run without that rear cover.It won't hurt anything.In fact is better for the rear clutch in keeping in cool.
