VeeDub Gasket Research
Based on word from VeeDubh, I recently looked into compatibility between AF16/18 exhaust port and gaskets from Vaunted Vintage Venerated Vee-Dub air-cooled engines. One O'Reilly's in Deepinnaharta had a dusty set on a back shelf, agreed to pop the box open to let me have a look:
Specs taken from Ultra-Fragile JW "Eggshell" gasket are recorded in the 5th post down on page 2 here.
I have yet to install them physically, but looks pretty much close enough, even if I have to round out the stud-holes one way or 't'other. The kit comes with a bunch of siamesed intake gaskets and "pre-heater" seals, as well as a couple of copper donuts of undetermined size. However 4 usable gaskets for $15 seems fair enough. Plus, they're Fel-Pro, the Gaskets Professionals Trust.
That or see your Authorized Volkswagen Retailer today, if "today" is in 1967!
Re: VeeDub Gasket Research
Good work all - With a name "VeeDub" it had to be the word :bowrofl:
BTW - I think these may be similar, if a large supply is needed :)
$0.79 each
http://www.mofoco.com/item/Gasket_Exhau ... 1_261B/578
If this is good enough (missing the internal ring?) they are 4 for $2.25
http://www.mofoco.com/item.php?item_id= ... gory_id=55
808BMW
Post by 808BMW »
Been running these for quite a while, works perfect.
Just make sure your bore is big and so is the exhaust ;)
evilone
Post by evilone »
808BMW posted a pic in aerorobs build of the VW gaskets. pic below shows one installed on Malossi 72cc jug. Cost is only $.50 each. Fits perfect and exhaust studs keep it centered. I have extras if anyone can't find them and want to run one.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Clivester
Post by Clivester »
Cheaper still seems to be RockAuto.
Only 21 cents or buy 10 and save 10 cents!!!
http://www.rockauto.com/catalog/raframe ... 207k477576
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
boojadean
Post by boojadean »
Would these work on an '85 Aero also??
'85 Honda Aero
'01 Honda Reflex
'84 Honda Magna
Clivester
Post by Clivester »
boojadean wrote:Would these work on an '85 Aero also??
Where's Wheelman when you need him?
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
evilone
Post by evilone »
Not unless you have a big bore with bigger pipe. the stud holes would end up on the part of gasket that "squishes" to seal.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
veedubh20
Post by veedubh20 »
metal vw gasket for mofoco , that fits fine on bbk ..79 cent
both dub gaskets are very huge on exhaust port.
ZMUD
Post by ZMUD »
I have those gaskets laying all over the place for my 73' vw bug/kitcar!
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
1"uni-filter,Keli 9g
1k center,8.44 gears,ZX Trans
V8 Pipe,IRC MB38 80/90 tires
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
1" Uni-Filter,8:44gears
Post by eliteguy50 »
So is there a difference in quality of these gaskets or one supplier that is better than another? Any to stay away from?
Just don't install the turquoise crushed eggshell one that comes with a lot of the Asian pipes. Otherwise, metal gaskets are metal gaskets, not artificial hearts. I hacked one out of copper sheet that worked fine for months.
808BMW
Post by 808BMW »
Wheelman-111 wrote:Greetings:
I'd test fitment before throwing it out, my blue pipe NEEDS the thick blue gasket they provide, it really affects the fitment of the pipe.
Good point. One could also stack several metal ones, but life's simpler with one thick one. Trouble is mine exploded during a WOT run. Can you say LOUD? It also runs like le poopage, and puts the bore at risk from inhaling air.
Treat the teal gasket like the eggshell from which it's made.
Keoni
Post by Keoni »
Hey guys, I'd also like to add the paper gaskets seal better and easier vs. the metal gaskets but the metal gaskets last longer if you aren't the type to be pulling your exhaust off every other day. I guess old VW parts are easier to come by here in Hawaii because we can walk into a bunch of different stores and buy them over the counter lol.
Those thick exhaust gaskets tend to be required nowadays for fitment issues, and they can be reused if you do take your pipe off every week.
VTCycles.com for performance parts.
