1985 Honda Spree NQ50
IowaHondaSpree
Post by IowaHondaSpree »
Is there any way I can Make this go faster? it only does about 25 mph.
snowmobiles
82 John deere liqufire
77 Sno*Jet SST
Yamaha Bravo
76 John Deere Cyclone
78 Kawisaki Intruder
Mopeds
1985 Iowa Honda Spree
1998 Yamaha Jog 50CC
martynkim
Re: 1985 Honda Spree NQ50
Post by martynkim »
Put a 3 X 10 tire out back and you will gain a few MPH
Fishman43
Post by Fishman43 »
Lots of posts, recent and old, about this subject. Use the Search function up above to find all kinds of answers.
Or you could always go with the stand by, "Dude swap in a Dio"
fightingplankton
Post by fightingplankton »
Fishman43 wrote:Lots of posts, recent and old, about this subject. Use the Search function up above to find all kinds of answers.
as can be seen in this amazing bit of wit from trafficjamz
http://www.hondaspree.net/phpBB3/viewto ... an+a+honda
'86 spree
'86 aero50
'83 aero80
IowaHondaSpree
Thanks guys, got one more thing is there any way I can mod the suspension so it sits up higher??? :?:
snowmobiles
77 Sno*Jet SST
Yamaha Bravo
Mopeds
fightingplankton
i have no valuable input
Last edited by fightingplankton on Mon Apr 05, 2010 11:03 pm, edited 1 time in total.
'86 spree
'86 aero50
'83 aero80
odinxxix
Post by odinxxix »
i think the ruckus was on the elite or the aero, find a shock from an elite(sa50) it will fit and give a better ride. 3.00 X 10 tires will do also but beware some mods may need to happen. to be safe try 2.75X10 its better the the 2.50X10 tire, its what i have on mine.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
madskater1987
Post by madskater1987 »
I'm running a ruckus shock on my spree with 3''x10'' tires. You have to move your shock mount point to under the oil tank. But I did it with no welding.
I also just streched the spree by making the motor mount a little longer and bolting it to were the center stand would mount. (with 3'' tires the center stand rubs on tire and wont ever reach the ground).
IowaHondaSpree
Can you drill the jets out in carb my jet is a speical one that Iowa requied so it wouldnt go over 25.
snowmobiles
77 Sno*Jet SST
Yamaha Bravo
Mopeds
odinxxix
Post by odinxxix »
you can drill it out, what size is yours 65?, drill out the restriction in the exhaust, up jet to 68, and get a set of taz gears. that should put you in the mid 30's you did say it was the iowa right? NQ50D denotes iowa model. if you need a 68 i believe i still have one here from my spree that i dont need.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
IowaHondaSpree
How do I drill out the restictoin in the exhaust? :newb:
snowmobiles
77 Sno*Jet SST
Yamaha Bravo
Mopeds
IowaHondaSpree
I messed my spree up I drilled the jet out in carb and now it wont run and is very rich with the air screw all the way in. :newb: :newb: :newb:
snowmobiles
77 Sno*Jet SST
Yamaha Bravo
Mopeds
odinxxix
Post by odinxxix »
drilling out the exhaust will need some sort of grinding tool. remove the exhaust and look inside where it bolts to the jug you will see a washer that needs removed,grind it out all the way. if you need a 68 jet i have one just let me know.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
