Transmission oil ?'s
Jhoodwink
Post by Jhoodwink »
I was wondering can I just use any SAE 10w40 motor oil? There aren't any special additives that have to be in it? Also when changing the transmission oil do you just siphon it out of the fill hole? Thanks in advance! James :D
James,
You only need to post questions once.
Manual lists 10-30W, Jerry recommends using 2-stroke oil. I defer to his experience.
Kikwear
Post by Kikwear »
Synthetic ok?
Jerry
Post by Jerry »
Synthetic is fine, but why waste it? Regular old two stroke is just fine.
Pull the plug, tip bike on side (protected), let drain, set on kick stand and refill.
Scoot safely
Tippmann98
Trans Oil
Post by Tippmann98 »
2 strole has its advantages and disadvantages. Yes, it burns off. So you HAVE to remember to keep putting oil. But with using 10-w40 it will not burn off as much and mostly stays till the next oil change. Any type of 10-w40 will do. You do not NEED any special additives, but considering the age of these machines. I am sure it will not hurt a bit. I use a transmission fluid made by honda, its red and is SAE 80w.
Jim
Post by Jim »
i work at Jiffy Lube, will the tranny fluid for cars work for the spree? if so i can get free fluid :) yay me!
83 Suzuki GS450E - Sold
Spree Repair Guide
80W? That's some pretty heavy oil to put back there, a lot thicker than the specified 10-30W oil.
Auto Trans fluid is 7W to 8W, with antifoaming agents added. I'm not sure what the viscosity of 2-stroke oil is. Since the rearend only take a fraction of a quart, cost has never been a concern. Auto trans fluid should work, but since Jerry's had good luck with 2-stroke oil, I'm sticking with that. :D
Kikwear
Post by Kikwear »
Still don't understand the 2-stroke vs 10-40W argument.
Two stroke burns off faster yet the factory recommends 10-40W. Any inherent advantages that the two stroke offers? Seems like you're increasing your service intervals if anything.
On another note, Honda Two Stroke oil at my Honda dealer...is that for injection systems and correct to use?
Jim
Post by Jim »
honda 2-stroke is what is recomended in the manual, it should say somwhere on the bottle about injection systems and that its ok for it.
Spree Repair Guide
Tippmann98
It is actually pretty thin stuff, honda made, runs pretty well. But on another point, with the type of 2-cycle you burn in the motor. I really do refer Lucas brand 2-cycle. It is a clear, TCW-3 and is "smokeless." Which it actually reduces the emission color a lot. Not to mention it cuts out most of that bad smell that two cycle has. It also cuts out on a lot more clogging, me and Shane4188 have seen this through use. Its a miracle Spree oil. But really, look into this stuff. It is about $7 a bottle, they carry it it Oriley Auto Parts.
Jim
Post by Jim »
I use Yamalube 8O
Yamaha's synthetic oil, seems to work fairly well and doesnt burn, also it "dramaticly reduces visible smoke" I like it and recomend it
Spree Repair Guide
Jerry
Post by Jerry »
Ya'll say what you may, but I'm sticking to two-stroke in the tranny. Sno-mo injection oil, never had a problem, never have noise, never have to wait for a warmup before I get top speed on the bike. Thicker oil is going to really slow you down, that's a given.
Tranny fluid for a car - no way. It's greatest purpose is to absorb heat and transfer it away from tranny. Roller bearings and sealed ball units are in most every auto transmission. The heat comes from the friction clutches, which must be kept cool. Mopar experimented in the 70's with auto tranny fluid in their stick shifts and it was a disaster. (Experience). New tranny, swapped to 75-90 and never another problem.
Scoot safely
Actually Jerry, you can run auto trans fluid in a properly designed manual. I had an '85 S-10 with a 5 speed manual, that called for auto trans fluid. The thinner oil gives better fuel economy.
Kikwear
Post by Kikwear »
Tipper, is this the Lucas you use? LINK
Jerry, how often do you have to maintain the oil level in the tranny?
Shane4188
Post by Shane4188 »
Yes that is what I use also.
