cathodes....
cathodes....
alright, I had read on here that one of you had hooked up cold cathodes, I was excited, i got some, and i think i busted em, i cant get these darn things to work... i had initially hooked them up to my tail light for a little just to see how they worked, i did that one time and it won't work at all anymore... I had even hooked them up to the battery, How sensitive are these things?
The ones i've got on my moped work like a charm http://www.xoxide.com/bluecathode.html I installed it in less than 10 mins and hooked it right up to the battery and it works fine. They are super bright to.....my friends could see them from 2 blocks away. so im not sure why you're having problems since its really easy. The ones i have wouldn't break even after from about 6 feet several times.
If you guys wanna see a video heres a link http://uafsite.tripod.com/Movie_0003.wmv
It was pretty crapily mounted with masking tape since its just a temporary one till the red ones come in....but has stayed on the past couple days riding around.
Any comments????
Any comments????
I use an led bulb, it pulsates, strobes and starburst and is a brake light for $10 at www.cycleimportshawaii.com
fdasf
What came in the mail was the 2 12" tubes, the wires to hook em up to a computer and a blue box that looks like a speaker/ transformer... i cut off the computer ends, and it worked, i took them inside, and went back out an hour later and they would not work... im so conflustered
fdgsd
i got rid of the switch that came with it right away, i cut off all computer ends and the switch was cut off as well, i was going to use my own that lights up. i must have blown some thing... any idea where i could get a new "box thing"?
