Honda will start but only run for about 1min Help
wannabie
Post by wannabie »
I have the Honda elite sa50 It will start and run for about a minute or more and then die. when I try to start it again it just makes a pop sound. but if I wait for awhile it will start and run for about a min.
Flea_Biskit
Re: Honda will start but only run for about 1min Help
Post by Flea_Biskit »
what year?
how many miles?
did it sit all winter?
clean the carb! :blah:
Ride it like you stole it'
Classic plugged up carb. Once the bystarter stops feeding extra fuel in to the engine the engine dies because it is too lean. Do a complete carb tear down and soak it in carb cleaner, make sure all passages are clear (the info on carb cleaning are in the Tech Documents) and you should be good to go. However, if it doesn't fix it, then clean the carb again, even the old pros have trouble getting the little passages clear on these carbs.
wannabie
Post by wannabie »
Thanks guys I will try this and let you know how it comes out.
IowaHondaSpree
Post by IowaHondaSpree »
A carb clean should fix it right up.
snowmobiles
82 John deere liqufire
77 Sno*Jet SST
Yamaha Bravo
76 John Deere Cyclone
78 Kawisaki Intruder
Mopeds
1985 Iowa Honda Spree
1998 Yamaha Jog 50CC
wannabie
Post by wannabie »
ok did the carb clean and it was still doing the same thing I pulled off the muffler and it stayed running. It was a pluged up exhaust. But thanks for the help
