Aftermarket Intake Mani and fuel petcock
Fishman43
Post by Fishman43 »
How do the aftermarket intakes work with the fuel petcock for the vac. function?
I ordered the OSO carb/intake kit from VT last week, now I am wondering if there is a direct connection or modifications are required.
Re: Aftermarket Intake Mani and fuel petcock
The CT has a barb for vacuum or oil, but not both. You can run a "Y" connector, but that may not be ideal. Better is to attach another barb, closer to the carb spigot, if you intend to run the pump with a vac petcock. 1/8" barbs with a small threaded section are exceedingly hard to find - thanks again Z50R-Blank! :hi: If you find a source, let us know?
Fishman43
Post by Fishman43 »
It is never easy with these dang-ol scoots is it!
tru72
Post by tru72 »
the real way to run a vacuum is to drill and tap a hole on the lower section of the manifold. What you trying to do is get it below the reed valve to make sure there is a constant vacuum. The other way works too but if you have the tools and time do it the other way. Ill try to get a pic of one I had done before.
aloha
D
Fishman43
Post by Fishman43 »
Maybe my physics are off, but below the reed vavle don't you get presure and vacuum? That is the reason for the reed valve in the first place to keep the presure out of the intake.
tru72 wrote:the real way to run a vacuum is to drill and tap a hole on the lower section of the manifold. What you trying to do is get it below the reed valve to make sure there is a constant vacuum. The other way works too but if you have the tools and time do it the other way. Ill try to get a pic of one I had done before.
aloha
D
Don't want to hurt you feeling but the crankcase goes from vacuum to pressure on each stroke (that's how 2 strokes work and the reeds stop the pressure from reaching the manifold). Whereas above the reeds the worst it is vacuum to atmospheric pressure to you recommendation is a poor one at best because it is hard on the petcock diaphragm. Better off in the manifold above the reeds, just like the factory guys have it.
Fishman43
Post by Fishman43 »
That is what I thought Bear, thanks for verification of the intake process on that!
tru72
Post by tru72 »
None taken bear, if thats is true what you say, and i agree with you, but if you seen a sym dd50 block the vacuum is located right under the oil pump. That is directly goes into a vacuum fuel pump. Now if above the reed cage was suppose to be better, why would they put it there? maybe because the pump works better with the pulse? The intake vacuum on a dd50 is what the oil pump is connected to. Not saying its right or wrong since it is from the factory..LOL maybe the Taiwanese got the directions and translations mixed up haha
bakaracer
Post by bakaracer »
tru72 wrote:None taken bear, if thats is true what you say, and i agree with you, but if you seen a sym dd50 block the vacuum is located right under the oil pump. That is directly goes into a vacuum fuel pump. Now if above the reed cage was suppose to be better, why would they put it there? maybe because the pump works better with the pulse? The intake vacuum on a dd50 is what the oil pump is connected to. Not saying its right or wrong since it is from the factory..LOL maybe the Taiwanese got the directions and translations mixed up haha
Hey D the sym dd50,arnada and dio all have the gas tank on the floor so a pulse style fuel pump is needed to get gas to the carb.the elites use a vacuum style petcock because the fuel tank is up high.
What he said! ^
Snowmobiles also carried their fuel below the carb. The "Pump" on some early models was a diaphragm affair below the float bowl, needing the +/- pressure pulses from the crankcase to operate. Some priming in -35 degree weather was a good idea, hence the marine squeeze bulbs found on those sleds.
z50r-ghost
Post by z50r-ghost »
Wheelman,
Dude, I still have had no luck finding those ever hard-to-find barbs... but, if i can manage to ever find them, I will order lots of them to share! -i have not given up yet dude.... :coolcruise:
jc
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
Fishman43
Post by Fishman43 »
How about these barbs? 1/8", male threaded, brass... seems OK to me.
http://www.plumbingsupply.com/barb.html
Now drilling and tapping the intake on the other hand :nervous:
I have a bunch of those. For the 1/8" barb you have to drill like 5/16 or larger hole! The ones Z50_R has/had use a nice little 5mm drill/tap combination and you're done. Took all of 10 seconds.
Fishman43
Post by Fishman43 »
Perhaps I am confused then, Wheelguru wrote:
Wheelman-111 wrote:1/8" barbs with a small threaded section are exceedingly hard to find - thanks again Z50R-Blank! :hi: If you find a source, let us know?
Are these barbs with 1/8"mips threaded sections not what is refered to above?
For a nipple - Try your local RC hobby shop. Fuel and pressure fittings in small sizes are often stocked. Just about all stock DuBro products like below (8-32 thread). That will fit 1/8" id or so tubing.
http://www.hobbypeople.net/gallery/868759.asp
This one is smaller, 6-32 thread
http://www.hobbypeople.net/gallery/567560.asp
