best engine swap for a spree
Posted: Wed Apr 07, 2010 10:06 pm
by nstampfel
Please give me opinions on what is the best engine swap for a spree and why. I messed around with Puch's for years but I just picked up a 84,85 and 87 spree and I want to build one up with a transmission that has a variator. New to Honda's please help
Re: best engine swap for a spree
Posted: Wed Apr 07, 2010 10:11 pm
by drizzle
the obligatory "dude! swap in a dio!"
(aka AF16 elite engine)
Posted: Wed Apr 07, 2010 10:52 pm
by madskater1987
II'm working on a build right now putting a gy6 150cc on a spree. Can anyone say 90mph.
Posted: Thu Apr 08, 2010 1:00 am
by bradthreee
I can say 90 mph but there's no way you'll go that fast...
Posted: Thu Apr 08, 2010 1:03 am
by bradthreee
If you can find a good deal on a dio aka 94+ Elite engine, then go for that. Next best thing is an SA50 88-93 Elite, SE50 87 Elite, or NB50 86+Aero.
Posted: Wed Apr 14, 2010 3:30 am
by matzke3
Im in the process of finishing up swap onto the spree. Theres a recent post in the scooter builds section where i copied the engine mount (not the shock mount though). This swap was an 87 elite (se50) engine onto an 86 spree. It wasnt too tough. I have a bbk and variator on the way. The author of that post states it should put it to 40 mph. Lots cheaper than a dio.
Posted: Wed Apr 14, 2010 9:16 am
Your '87 AF05 Elite engine should easily exceed 40, particularly with a big block. Just be careful about sustained WOT, because stock gearing may not be tall enough. If your particular engine has the elusive 10:1 gears and you can add a 3.50 or 90/90 tire, that may be enough. If not, exercise discretion (and install a Tach) on long downhills.
Posted: Wed Apr 14, 2010 5:14 pm
by matzke3
Wheelamn, I am planning on running a small premix in addition to the oil pump and running a little rich to try to keep it together. I checked when I got the doner and my se50 has the 11 to 1 gears
I would like to swap in taller gears like from a dio but can't find them. Any ideas?
Posted: Wed Apr 14, 2010 6:42 pm
Search for Malossi 67-6458 gears from an European parts store like 50cc.eu or Scooter-Center.com. They're getting rare even over there. The Aero/SE name in Europe for
most parts is Honda
Vision. A 3.50 tire and a mild bore kit might not exceed safe RPM threshold. Then again, it might...
