How to wire a tachometer? 84 spree
patthesoundguy
Post by patthesoundguy »
can any of you wiring gurus out there help me with tach wiring, I have and old tach that I want to hook up, just not sure how to mate it to the cdi setup on my 84 spree, I'm sure some of you guys have done it.
Re: How to wire a tachometer? 84 spree
First, not just any tach is gonna work. A car tach with 4-6-8 settings will not work, it will read anywhere from 1/2 to 1/4 of your actual engine rpm. You need a tach for a 2 stroke. Wiring the tach will depend on what kind of tach you have. A Tiny Tach has built in batteries and to connect you wrap the wire around the spark plug lead and ground the other lead (if it has one).
Hi - welcome back!
Like Bear says, there are a lot of ways to for a even a cycle tach to interface.
Here's some links to tachs showing a few different connections. Some have adaptors, inductive pickups, some tie into the coil wiring and some are just a wrap of wire around the ignition coil wire.
http://www.autometer.com/download_instruction/369N.pdf
http://69.20.53.62/pdf/90001005b.pdf
http://www.tinytach.com/tinytach/installation_com.html
http://www.demonscycle.com/Electrical-C ... 8-1-2.html
patthesoundguy
thanks guys those links will give me a really great start, i figured the 4 stroke tack would show 1/2 or 1/4 speed but if I can get it to work in that state that is all I really need for now, I just want a cool gadget that moves when i rev up. And down the road when i can pony up the cash for the right rig i will do that for sure. one of those links will have the answers i seek i'm sure. and whewn I have tach in hand i'll post somee pics. Here is one like the tiny tach but pretty cheap!
paul68firechicken
Post by paul68firechicken »
Hello all,
New to this forum looking for information on sun pro 2 tach mods. Found on a web search where mousewheels had made mods to these tachs. Would like to get in touch to discuss a project I’m working on.
paul68firechicken wrote: Mon Nov 23, 2020 7:14 pm Hello all,
I will get a message out to mousewheels and try to get you some help sir....motor
