Compression ratio
VolvoJoe
Compression ratio
Post by VolvoJoe »
Ok so I bought this Spree and have not had time to work on it so I took it to a shop. The guy said he couldnt get it started so he check the compression ratio and said it was 60. Does anyone know the compression on these engines are? Thank you
Re: Compression ratio
60 is too low 125- 135 is good
The manual says and I quote "8.0 kg/cm3 (114 PSI) Minimum. 60 means a minimum of stuck rings.
Compression ratio for a Spree is 7.2 to 1 thru '86, 6.8 to 1 (7.0 to 1) after 86.
Bear45-70 wrote:The manual says and I quote "8.0 kg/cm3 (114 PSI) Minimum. 60 means a minimum of stuck rings.
Normal atmosphere pressure (1 bar) = 14.5037738 lbs (at sea level)
So your comp ratio is 60/14.503 or 4.137:1 which is way too low :sad: (math edit) still way too low :geekdance:
Are 7.2:1 and 6.8:1 minimum ratios or normal specs?
So your comp ratio is (60+14.503/14.503 or 5.137:1 which is way too low :sad:
Last word in first sentence.
:? The reason I ask. 7.2:1 and 6.8:1 do not equal 114psi. 114/14.503 = 7.86 :? So which one is it?
Trafficjamz wrote:
Bear45-70 wrote:
Trafficjamz wrote:Normal atmosphere pressure (1 bar) = 14.5037738 lbs (at sea level)
The thing you are missing is that 2 strokes are super charged by design. The mixture is compressed in the crankcase first, so that when the intake port opens the mixture is forced into the chamber under pressure, there by making the compression ratio higher (called dynamic compression) than the static compression numbers show.
So 114psi is the lowest allowable dynamic comp ratio? :?
What should the static comp ratio be on good running spree engine?
Trafficjamz wrote:So 114psi is the lowest allowable dynamic comp ratio? :?
Static compression is done just like you did it earlier. But static is just a number whereas dynamic is what you have to live with with a running engine.
Post by eliteguy50 »
The lowest recommended pressure, yes. Dynamic is basically a measure of the atomic mass in the cylinder and static is the linear measurement of volume.
I would say 90psi at a minimum. The engine will run below that but you don't want to risk breaking a ring. The other problem is that compression gauges have hoses and the longer the hose, the more volume is offered for diffusion of the 50 cc output of the motor...longer the hose, the lower the reading. I had a gauge that read 56psi and the engine still ran (not well but would go 20mph). I made a new gauge with a shorter hose and it was roughly 20psi higher.
The hose thing is a very valid point. The shorter the better for accuracy.
