Cheap Oil Plug
Bugaboo
Cheap Oil Plug
Post by Bugaboo »
Inspired by Trafficjamz money plug. Just nut, bolt and washers. Gasket under the largest washer
It's official! I'm addicted
Re: Cheap Oil Plug
Let us know how that works out for you.
If it does not work, VT cycles has them for forum members for $9
I am an inspiration to many. :wink:
Bugaboo
Re: Cheap Oil Plug
Post by Bugaboo »
what's good to cap the oil inlet to the manifold? And how much would you up jet when you premix? Se50 starts with an 85.
Re: Cheap Oil Plug
JB weld or five min epoxy and a tiny screw.
If you are handy with solder, this can work too.
bartle90
Re: Cheap Oil Plug
Post by bartle90 »
How did this work out for you and what size bolt/washers did you use?
fastplastic
Re: Cheap Oil Plug
Post by fastplastic »
bartle90 wrote:How did this work out for you and what size bolt/washers did you use?
washers are easy take a pennie out of your pocket and a quater go to hardware store, then find 17 pennies and stack them up and messure how tall they are and get a bolt a lil longer so you can fit the washers that are on the out side too!
Bugaboo
Re: Cheap Oil Plug
Post by Bugaboo »
That's how I did it. I think a quarter was too big so I found a washer slightly smaller than a quarter and then I just bought like 20 washers the size of pennies. Don't remember how many I used.
Re: Cheap Oil Plug
Bugaboo wrote:what's good to cap the oil inlet to the manifold? And how much would you up jet when you premix? Se50 starts with an 85.
They make rubber caps for that and a tie strap to hold it or if you are insecure and hose clamp. The screw and JB or epoxy is to permanent for my tastes. A cheap and quick was is a short piece of hose then a screw into the hose, with the option of a tie or a clamp. But I have never had a screw come out in 50 years.
Up jet for premix should require no more than 1 step.
Munstah666
Re: Cheap Oil Plug
Post by Munstah666 »
Do it right, BUY the RIGHT plug. GL! :thumbwink:
µùѵ£¼Òü«Òé╣Òâ╝ÒâæÒâ╝Òâ×Òâ│
Bugaboo
Re: Cheap Oil Plug
Post by Bugaboo »
Just did a pressure test with my oil plug today and it definitely leaks. Put stock pump in with inlet and outlet attached together with hose. Pressure at oil plug good now. I think the failure in my design is sealing the threads in the bolt. Maybe i'll put some jb weld on it and see how it holds. Also suspect the stock bolt that holds the stock pump in doesn't do well holding in the plug.
Re: Cheap Oil Plug
Bugaboo wrote:Just did a pressure test with my oil plug today and it definitely leaks. Put stock pump in with inlet and outlet attached together with hose. Pressure at oil plug good now. I think the failure in my design is sealing the threads in the bolt. Maybe i'll put some jb weld on it and see how it holds. Also suspect the stock bolt that holds the stock pump in doesn't do well holding in the plug.
Just use hardening gasket sealer or Loc-tite. JB is a poor choice for a place that is going to go through heat cycles.
Bugaboo
Re: Cheap Oil Plug
Post by Bugaboo »
Hey Bear. I'm looking for a good sealant/gasket maker for manifold. I know most gasket makers are not rated for contact with gas
Re: Cheap Oil Plug
Bugaboo wrote:Hey Bear. I'm looking for a good sealant/gasket maker for manifold. I know most gasket makers are not rated for contact with gas
For the intake side, which is low pressure, actually low vacuum, you can use fuel resistant RTV.
dun rite
Re: Cheap Oil Plug
Post by dun rite »
Hello:
Bear45-70 wrote: Put stock pump in with inlet and outlet attached together with hose.
doesn't the oil pump need to be lubricated? hate to see it come apart inside the case. Check with the more knowledgable people here on the forum to be sure..
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
Re: Cheap Oil Plug
dun rite wrote:Hello:
You obviously have no clue about what he is doing. :roll:
Oh and where the * did I ever say to loop the output to the oil inlet? Never said that because I don't believe that is a safe or a smart move.
