Ruckus Vari needs belt to benefit?
akskoot
Post by akskoot »
Am I correct in assuming that without a longer belt there would be no benefit to adding a Ruckus vari? And with a longer belt, a ZX trans would then be needed to keep the belt from over riding the outside of the rear driven pulley?
1985 Aero 50--'87 AF05 motor, ported and polished, Ruckus Vari, 1.5K torque spring, 1K clutch springs, drilled exhaust/airbox,#85 jet, Pirelli 3.0-10s= 45mph flat
http://www.myspace.com/the1120s Image
drizzle
Re: Ruckus Vari needs belt to benefit?
Post by drizzle »
ruckus variator and stock belt saw me at 40mph, as apposed to the old stock 35mph. so it definitely helps.
Greetings
If all you're swapping is the Vario, the Ruckus model is a good option. The longer-belt thing (with or without bigger rear pulleys) is mainly about take-off.
I have heard of no problems with stock Ruck-sized variators. With a very big aftermarket Ruck variator you may encounter an issue with the stock-length belt "bottoming out" betwixt the rear pulleys - and possible breakage if prolonged stress. A slightly-longer Polini 284-006 is a good choice for stock pulleys with a carefully-selected shim between the front pulley boss and the ramp plate ~0.7mm thick.
akskoot
Post by akskoot »
Thanx for the replies. But I still fail to see how if my belt doesn't reach the outside of a stock vari at top speed, why would a few more unreachable millimeters of diameter on a Ruck vari be usable. I would love to believe that the Ruckus vari alone improves top speed, but I need someone to help me wrap my head around how and why. Wheelman were you saying that the Polini belt is a good choice for stockish sized variators coupled with a ZX trans?
trains420
Post by trains420 »
depending. on if stock actually makes the rear pulley, the smalles, as in the clutch pulleys spread all the way out.
since the ruckus variator has the same 30 degree angle, 651-15.5-30. something like that, the belt won't go up any higher on the front, just will be squeezed up higher. your drive boss will make the belt width, which is what would get squeezed out, is the belt width you use. the drive boss, the cylinder in the middle of the variator, it goes back to the ramp plate on the variator, pushing it out and the variator back and forth, and you got your starter gear, or the front half of the front, or variator pulley. pushing it off, i don't think can happen, but it could be pushed up high, and it squeezes the clutch apart in the back, and get to the bottom and still not be at teh top of the variator, and it would squeeze the belt, and may break it if it's not stretched.
when you get a belt, there's three measurements. or you buy honda. length, width, and angle. width is from drive boss, length from size of middle of variator, and middle of the clutch when the belts around it. angle is angle of both pulleys going in. what there angled at.
Poor Man's ZX Trans
The ZX pullies must use an 18mm belt - either 654 or 669 mm length. (That figure is nominal: the actual tape measurement around the outside is considerably more than the stated sizes...)
The Polini 248-006 is about 15 mm longer than stock, and about 16.2 wide. It won't work with a ZX rear pulley. It's too narrow to be forced up to the rims when the contra spring squeezes the sheaves together.
Used with stock pulleys, the -006 helps take-off because it can be made to ride closer to the edge of that REAR assembly. In order for that to occur, the pulley boss in FRONT must be shimmed to let the wider belt down all the way to center in FRONT. about 0.7mm will do it with a new one. Thinning the shim as the belt wears down will maintain good contact, if you're a bit OCD.
If that's all you do, the -006 will hurt top speed a little because once underway the belt is now too long. When it reaches the rim of the front pulley, it won't be pulled as far down to center out back. The remedy for this is the larger-diameter Ruckus variator. I call these combined mods the "Poor Man's ZX Trans." The only hard part is sourcing the belt number from Polini - it fits no scooter ever sold in the US, AFAIK.
Reason: Cleaned up and posted in Advanced Tech
akskoot
Post by akskoot »
Nice explanation. The shimming, the belt width. I get it now. :arrow: So in conclusion, shimming and added belt length are required to see the true potential of a Ruckus vari. swap. That's not an extra Polini .006 there is it? :hi:
Yeah, I guess I could sell it...
I added a Search link in the Tech Docs version of this thread in case you'd prefer to buy new. Mine has a couple hundred miles logged. I haven't measured it lately but it's at least 16mm wide. I have a couple nearly-new stock Gates - Honda belts too.
akskoot
Post by akskoot »
I'd just like to say, Drizzle you were right. With a Ruckus vari and stock belt I saw a substantial top speed increase, up to 5 mph(unconfirmed except for speedo guestimate). I think I'm around 46 on flat, up from 41. I'm gathering washers to try out my Polini .006, but it hasn't made it off the bench yet. It's mighty close to running out of threads on the driven gear once I shim the vari. Too scary to try...
maddog
Post by maddog »
all i need to know is how many high spots on the case need to be shaved and why is a japan zx bando belt not used along with a zx drive face+boss=this convertion is a joke :smile:
losthope
Post by losthope »
maddog wrote:all i need to know is how many high spots on the case need to be shaved and why is a japan zx bando belt not used along with a zx drive face+boss=this convertion is a joke :smile:
Its an old school secret trick. PM me and ill tell you the secrets
evilone
Post by evilone »
:bowrofl:
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
