Page 1 of 2
Help with a Piaggio Fly 50
Posted: Wed Apr 21, 2010 10:05 pm
by Trafficjamz
This scooter will not start or even act like it wants to start ever.
I took a compresion test and it was 150psi
I checked for spark. It had spark.
Well since it had both spark and compression, I figured it must be a fuel issue.
But even when I sprayed starter fluid , It did not even pop or anything.
I am stuck and don't know what to check now.
PLEASE HELP
PS the Piaggio 50 is a 2007 and it is a four stroke. I did also check to see that the valves were moving up and down and the timing chain is not broken.
Re: Help with a Piaggio Fly 50
Posted: Wed Apr 21, 2010 10:50 pm
by mustangwagz
Did you try changing the plug? i assume you checked spark with the plug out of the cylinder. in natural atmospheric pressure it IS possible for the plug to conduct spark, but then when put into a Harsh environment such as being pressurized at 150 psi, it is possible for the plug to be to weak to conduct electricity. I've seen it on cars before numerous times.
maybe also try pullin plug, and either puttin in a small small small amount of gas, or startin juice in the cyl, screw the plug in real quick and spin it over. maybe that'll narrow down a bit. I've seen ALOT of these china made scoots and quads and pit bikes have Valve Clearance issues. What i mean is are valves adjustable, and if so, whats the clearance gap between rocker arm and valve top?
my buddy's pit bike was exact same way. We opened valve clearance to .004 on both intake and exhaust and it ran again. .004 worked, but he ended up puttin it upto .007 cuz tolerances were upto .010.
Lemme know what ya fidn out man!
Re: Help with a Piaggio 50cc scooter
Posted: Thu Apr 22, 2010 12:31 am
by Trafficjamz
mustangwagz wrote:Did you try changing the plug? i assume you checked spark with the plug out of the cylinder. in natural atmospheric pressure it IS possible for the plug to conduct spark, but then when put into a Harsh environment such as being pressurized at 150 psi, it is possible for the plug to be to weak to conduct electricity. I've seen it on cars before numerous times.
I did try to squirt some starter fluid in the spark plug hole, then replace the plug real quick......but still no bang.
I have not tried another plug, but the one I have is brand new, the porcelin is still white.
More Ideas please.. I am really stumped on this one
Posted: Thu Apr 22, 2010 5:40 am
by mustangwagz
Get me the motor model number if possible. ill look up the china specs on the valves. its worth a shot. 9 outta 10 of these china made motors has valve issues. Its got spark AND if you put fuel in it manually, it should fire unless it aint Firing or none of the valves are opening? in my opinion.
Hey how about timing?
Posted: Thu Apr 22, 2010 5:59 am
by martynkim
Piaggio is an italian scoot like a vespa you don't want it just send it to me.
also it is likely a fuel injected bike
Posted: Thu Apr 22, 2010 10:17 am
by Trafficjamz
martynkim wrote:Piaggio is an italian scoot like a vespa you don't want it just send it to me.
It is Italian. Maybe I should throw some spaghetti at it?
So What is this carb doing here
Maybe the NEW ones are FI , but this one is not.
It is only a PIMA
Posted: Thu Apr 22, 2010 10:25 am
by Trafficjamz
mustangwagz wrote:Get me the motor model number if possible. ill look up the china specs on the valves. its worth a shot. 9 outta 10 of these china made motors has valve issues. Its got spark AND if you put fuel in it manually, it should fire unless it aint Firing or none of the valves are opening? in my opinion.
I have no reference to check timing. This is not a cheap chineesy, but it is built just like one.
There doesn't seem to be any marks on the fly wheel for timing. (just the pickup marks)
Any info on how to check timimg a cheap chineese would be great.
I will check the valve clearance to day and report back.
Posted: Thu Apr 22, 2010 5:37 pm
by martynkim
Hold the meatballs
Posted: Thu Apr 22, 2010 6:57 pm
by mustangwagz
Currently awaiting another individual to get back to me with any info he can so ill keep ya posted.
One other thought i had was maybe a weak coil?!
i mean, its got compresion, spark, fuel it dont neeed much more as we all know. I mean maybe try all the obvious but un thought of stuff. Muffler plugged?! Intake pipe plugged? Something aint right here. lol
Posted: Thu Apr 22, 2010 9:18 pm
by mustangwagz
i aint heard nuttin yet bud, but here check out this site. i bet ONE DOLLA!!, that someone on there can get ya runnin or headed in the right direction!!
http://www.apriliaforum.com/forums/foru ... y.php?f=25
Posted: Thu Apr 22, 2010 10:23 pm
by Trafficjamz
Oh yeah I need to send your bling out to you asap. your dollar comment reminded me. I will send your bling in the mail tomorrow.
Posted: Thu Apr 22, 2010 10:25 pm
by mustangwagz
M'kay. sounds good man.
didnt make any headway on the spaghetti cruiser?
Posted: Fri Apr 23, 2010 2:37 am
by Trafficjamz
Posted: Fri Apr 23, 2010 2:49 am
by Trafficjamz
Posted: Fri Apr 23, 2010 4:36 pm
by eliteguy50
I don't know about the 50 but I know there was a bad circuit board in a fly 150 at my local dealer. It would only get up to 25mph. Maybe if the 50 has it, it won't start at all
