MSD blaster coil for Spree / Elite
Moderator: FAQ Moderator
deathwish
Post by deathwish »
o well i have done almost everything i can do to my 84 spree it hits aroun36-38 on flat ground i would like to get it over 40... so i was think on get the msd blaster coil.... has anyone put this on a spree or will it even work for the spree???? also were would i be able to get it???
Wanna kno how to keep an idiot busy for hours look below
Wanna kno how to keep an idiot busy for hours look above
maddog
Post by maddog »
It should work on the spree, my italjet has an intragraded cdi/coil unit so it will work, i also run oversized tires on my aero & elite but i don't know if you can do it on a spree, depends on the bead.
It will work on a Spree, pretty much a direct replacement for the stock coil, you can even use the stock plug cap. Diosoljah had posts showing a hookup, before he went through and deleted every single thing he'd ever written...8O never could figure out what exactly happened there. He had his in place of the (removed) oil tank.
deathwish
Post by deathwish »
alrite im gonna look into some more but i think it sounds pretty good
vette76
Post by vette76 »
noiseguy wrote:It will work on a Spree, pretty much a direct replacement for the stock coil, you can even use the stock plug cap. Diosoljah had posts showing a hookup, before he went through and deleted every single thing he'd ever written...8O never could figure out what exactly happened there. He had his in place of the (removed) oil tank.
i believe what happened is, he removed all his pics because of the reciant scoot thefts down there. he did not want anyone to trace the connection through the image host. i believe that happened on another site.
87' spree (SOLD
12' wrx
maddog
Post by maddog »
Well you boyz are up all night trying to find out the secrets on how to get h.p. from a stock honda spree, well you cam't
darat
Post by darat »
lol if u have the tools and the knowlage u can do anything u want.
deathwish
Post by deathwish »
well i looked around a couple stores and it seems i cannot get the msd blaster coil from any canadian dealers.......any one know a source for these?????
vette76
Post by vette76 »
jegs, summit, ebay....exc.
87' spree (SOLD
12' wrx
diosoljah
Post by diosoljah »
Okay here it is again...Tip ( just dont let the coil and the wire touch the bare frame) Ive used a cutting of a bicycle tire tube at the base of the coil.
MySpree
Post by MySpree »
whered ur oil tank go?
He's running premix, I'm sure, since the stock oiler won't be able to keep up with the increased bore/stroke combo.
diosoljah
Post by diosoljah »
noiseguy wrote:He's running premix, I'm sure, since the stock oiler won't be able to keep up with the increased bore/stroke combo.
yup hes got that right!
maddog
Post by maddog »
You can run the oil pump up to 76cc, after that its pre mix only.
darat
Post by darat »
how do u know this that the oil pump can handle up 76CCs? does this go for the elite oil pump to
Locked
