Will a By Turbo Muffler Fit On a Spree?
- KillinSpree
I was wondering if a By Turbo Muffler like they put on the tomos mopeds will fit on a spree to make it faster? let me no, if so than i might buy one.
NO, the express is a horizontal bore and yours is a vertical, check out this website www.sonicjay.com also go to www.50cc.nl and see if they made a euro or Japan version of the spree, i called the shop i deal with but a rookie answered the phone and was no help.
- KillinSpree
by turbo muffler
But if you had one and you knew how to weld good couldnt you like cut off the end and weld on another end to perfectly fit your spree? If you have the machanical ability to do such a thing. If so than that would be awsome.
Yes, its called cut /splce & weld, it looks like the engine pipe mounts may fit off an aero or etile-s pipe which are less restrictive or if you have bucks get a sef pipe, meassure the mouting bolts distance on center and i can tell ya if it will fit, you can elongate the holes if you have to.
Or do this. This worked for me:
http://hondaspree.net/modules.php?name= ... opic&t=946
This is a $20 pocketbike pipe retrofitted. Cut and try with cardboard b/f welding, but it's still too close to run for long (will melt the shroud.)
Admin, Hondaspree.net
- KillinSpree
by turbo pipe
That is Awsome. I just might have to try somethin like that. Thanks for the idea.
- KillinSpree
hp
Go to WWW.SONICJAY.COM/SPREE
its a pretty kool site about sprees
- wickedSpree
