OKO CT Manifold on an AF05E / SE/05 Block
Moderator: FAQ Moderator
Scooterwerx concocted one of these for himself, and swapped one to me:
That's right, an AF05 with a CT Chrome manifold. You just need to fill the 1/8" gap to the inside with a plate of metal or composite material. This opens the door to any CT-compatible carb up to 34mm, not that you'll need that big on 65cc. But it can be done.
Re: OKO CT Manifold on an AF05E / SE/05 Block
MMeadows just PM-ed me that the Aero 80 reeds perform the same function and offer a bigger surface intake area. No direct info, but maybe he can post this in Performance Technical with pics and we'll move it here for Posterity.
