I managed to get it to start by shear persistant kick starting but it would die if i gave it any throttle and even if i didn't it would slow down and stop.
I gave the carb a good cleaning ( it didn't look too bad ) and put it back in and tried to start it without the air filter on. No good. On a whim I covered the air hole on the carb while kicking it and got gas on my fingers, then i let it back open and it started up and it ran. When it started to die like before i covered the airhole again and it reved back up from death! Every time the idle would start to slow if i covered the hole for a sec or two it would run ok. I drove it around and after it warmed up it ran totally fine and wouldn't die.
Is my autochoke bad? I did that test where i pull it out a bit and try to start with no luck so that would indicate thats not the problem. Since its obviously not getting enough gas - is it the petcock? I know you have to have the air filter and box on too.
Also when I went to drain the fuel line by disconnecting it from the carb it slowly came out for a bit and then stopped completely with lots of gas still in the tank. Is that right - or again - is the petcock clogged?
Thanks guys for the awesome site - after i get her running well its time for performance mods right?
