sa50p clutch engagment springs?
i went to buy 2k springs for my 01 sa50p and justwanted to ask how exactly they worked. my idle is set at 1800 rpm and it seems like to me that the stock springs must engage right around 2000 rpm. will 2k springs really make that big of a difference in my take off?
Sa50p: port/polish, custom vari, 88mj, restrictions removed. 47 mph
PimpinSpree
Re: sa50p clutch engagment springs?
2k is 2,000 rmp over stock, so if stock engages at 2,000. with 2k clutch springs your clutch will engage at 4,000rpm. It will only help with the initial jolt, but 2k would probably feel completly different
i have 2 k grab springs in mine and launch is awesome!!!
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
Wow. Thanx fellas. I ordered the 2k springs and a 9:1 final drive. Hoping for a big change.
did you order 9:1 secondary or primary? i got the secondary and run really well!!
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
don't forget the roller weight pack because your going to need it.don't expect to get it dialed in with just a few different weights.it takes more than that.and don't forget the center spring too.if you change one thing something else has to change too.thats how the tunning goes in these cvt trans.
Not sure. I paid $55 for them. I should check
speaking of rollers i installed 7.5 gram. but if you are running stock variator then i would think about going to a performance one.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
- LocoParaHonda
I seem to recall someone saying that although it speeds up your initial takeoff, it somewhat slows the acceleration at high speeds?
Any truth to that?
I don't know if I'd be willing to make that trade off.
Any truth to that?
85 Honda Aero 50 w/kickstart and Keli variator. (Proteus)
86 Honda Aero 50
87 Elite 50-S parts ped
86 Honda Aero 50
secondaries then. Doesn't matter much other than the ease of install or swapping ratios.premix56 wrote:Not sure. I paid $55 for them. I should check
- Trafficjamz
Clutch engagment springs have no negitve affect acceleration at any speed.LocoParaHonda wrote:I seem to recall someone saying that although it speeds up your initial takeoff, it somewhat slows the acceleration at high speeds?
Any truth to that?
I think you are getting clutch engagment springs confused with center springs.
