The service manual says I need an NGK BPR6HSA plug for my '86 Spree. Will the BPR6HS for the '84-'85 Spree's work? The reason I ask is, I'm trying to get this thing running by this weekend and the BPR6HS is all the shop has in. Any help is appreciated.
Thanks, Roemer7
Spark plug question...
its fine to use, the A stands for extended life model. no biggie
83 Suzuki GS450E - Sold
Spree Repair Guide
Spree Repair Guide
Thanks, it worked just as you said. Originally, I found the gap on my old plug was something like 0.1mm, not good! So when I gapped the old plug correctly, I couldn't get it to run. I bought the new plug, gapped it correctly, and now we're off and running. (And running very well, I might add.) Thanks for the help.
Roemer7
Roemer7
