Starts cold, runs, hard time restarting when warm.
jsun3thousand
- BMX
First, I would like to thank everyone that has provided any information to this website. I have spent many hours on this site and have gone from knowing nothing to feeling fairly competent talking about my spree.
I just recently installed a 44mm bbk from Taz. My spree starts from cold just fine and runs better than it ever has. The acceleration is amazing. My problem is that it is almost impossible to start when the engine is warm. This defeats the reason I got my scooter, which was to be my main commuter around town.
When the engine is warm it sounds like it wants to start but never does. The more I attempt to start it when warm, the further it sounds from starting.
Spree stats:
Cold compression 116
Warm compression 110
The plug chop is good
Running 30:1 pre-mix during the break-in
Installed the jet that came with the bbk
Carb was cleaned before the install
It starts and runs with or without the cover on the airbox when cold.
About 20 miles into the break-in. Never gone over 20, no WOT, and no long trips.
All suggestions and comments are welcomed. If I'm doing something wrong, I want to know. Jason
Spree stats:
Re: Starts cold, runs, hard time restarting when warm.
Fatten up you idle mixture screw an 1/8th of a turn at a time, until it starts warm.
FYI, your compression should be higher warm than cold, something isn't right.
jsun3thousand
- BMX
I'll double check the compression tomorrow.
Also, when you are trying the warm start, have you tried giving it just a little throttle. My 1985 requires that in the warmer weather or when it has been run hard and I do a short shut off time.
jsun3thousand
- BMX
Warm compression is 120. It started cold no problem twice today. I turned the idle screw and gave it gas, like suggested, but couldn't get it to start warm.
Can you elaborate on the reason behind this? I feel i have the same problem with my scooter. Why is it so hard to restart?Bear45-70 wrote:Also, when you are trying the warm start, have you tried giving it just a little throttle. My 1985 requires that in the warmer weather or when it has been run hard and I do a short shut off time.
1993 Elite - The Mad Max
mine does that but always restarts, like its not getting enuff air to restart warm.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
For a bit i thought it was a bystarter issue, but i'm not sure that's the case
For a hot start the bystarter is not doing anything to help with the start.mr pibbs wrote:For a bit i thought it was a bystarter issue, but i'm not sure that's the case
As to cracking the throttle slightly. A hot motor contains hot air which is very thin compared to cold air. Hence your engine may be rich (why there is no need for the bystarter on hot starts) and, the cold air leans it out and allows for an easier starter.
If your engine does not want to start hot, even with the throttle cracked then there maybe a vacuum leak or a low float bowl setting.
jsun3thousand
- BMX
Would the fact that I'm running 30:1 premix and have a hot engine be causing my restart problems?
Maybe, what jet are you running?jsun3thousand wrote:Would the fact that I'm running 30:1 premix and have a hot engine be causing my restart problems?
jsun3thousand
- BMX
The one taz sent with the kit. Not sure of the size.
- JohnRobHolmes
- Goped
Is the condenser located in a spot where it gets hot? Have you tried swapping it out?
what is your plug gapped at?what plug are you using? how many turns out do you have the air fuel screw?
What condenser might you be talking about and what is it suppose to be doing?JohnRobHolmes wrote:Is the condenser located in a spot where it gets hot? Have you tried swapping it out?
