Any ideas on how to troubleshoot as to why its sticking?
If I give the lever a squeeze it will lock up the brake until i mess with the very end of the brake line where it ends with the nut-thing by the wheel. ( Ive unscrewed it now to where it just spins when i turn it... Anyone have any idea whats going on?
front brake sticks - what to do?
- ryanmcfinney
- Goped
Try re-lubricating the front brake cable, the swivel joint on the front brake hub, and/or lube up the front brake lever. I would first try those things, and if that doesn't work, then you might have an internal problem with the brake shoes or the return spring. Let us know if that works or what you find out.
Good luck,
JF
Good luck,
JF
1978 Puch Free Spirit, a 1980 Honda NC50, a 1985 Honda Spree, and a 2005 Yamaha Zuma. Gotta love two-stroke power...
- ryanmcfinney
- Goped
- e_racer1999
