Page 1 of 2
spree clutch, and mystery clutch
Posted: Sat Jun 19, 2010 2:18 pm
by tha juggalo boss
Does any one know what the difference is if any between the clutch with 2 arms and the clutch with 3 arms(besides the fact that one has two arms and one has three)? i.e. Wich one is better, worse, or same-if there is any difference between the spring tentions in the two, and if the springs are different, could you benafit from swapping them around In any way?
Re: Spree clutch
Posted: Sat Jun 19, 2010 2:22 pm
by Trafficjamz
tha juggalo boss wrote:Does any one know what the difference is if any between the clutch with 2 arms and the clutch with 3 arms(besides the fact that one has two arms and one has three)? i.e. Wich one is better, worse, or same-if there is any difference between the spring tentions in the two, and if the springs are different, could you benafit from swapping them around In any way?
I am pretty sure the clutch that has 2 arms is from an elite e.
Hmmmm this give me an idea
Re: Spree clutch
Posted: Sat Jun 19, 2010 2:44 pm
by tha juggalo boss
@Traffic Jamz- your comment about the springs on the spree clutch- in your reply to my question about the clutch mod got me thinking as well- we may be thinking along the same lines- let me know what you come up with!
Re: Spree clutch
Posted: Sat Jun 19, 2010 6:38 pm
by ae86guy
i got some 2000rpm clutch springs that are for a variated afo5e they wouldnt fit in the spree clutch they were about 3mm longer so i heated up the two ends with the hooks on them and bent them in till each spring was about 1mm shorter than the standard ones fitted them up and it works mint they dont engage the clutch till between 2000 and 3000rpm it made a decent difference in take off when im slowing down from WOT the clutch disengauges at about 15mph and motor drops back to idle with the standard springs in it the clutch engauged as soon as you gave it a bit of gas when im at the lights now i can give it a few revs without moving i just love the sound of the exhaust i made
Re: Spree clutch
Posted: Sun Jun 20, 2010 4:39 am
by Trafficjamz
ae86guy wrote:i got some 2000rpm clutch springs that are for a variated afo5e they wouldnt fit in the spree clutch they were about 3mm longer so i heated up the two ends with the hooks on them and bent them in till each spring was about 1mm shorter than the standard ones fitted them up and it works mint they dont engage the clutch till between 2000 and 3000rpm it made a decent difference in take off when im slowing down from WOT the clutch disengauges at about 15mph and motor drops back to idle with the standard springs in it the clutch engauged as soon as you gave it a bit of gas when im at the lights now i can give it a few revs without moving i just love the sound of the exhaust i made
Nice!!!! You should post pics
Re: Spree clutch
Posted: Sun Jun 20, 2010 4:40 am
by Trafficjamz
tha juggalo boss wrote:@Traffic Jamz- your comment about the springs on the spree clutch- in your reply to my question about the clutch mod got me thinking as well- we may be thinking along the same lines- let me know what you come up with!
Can you post a pic of the two clutches side by side(2 arm & 3 arm)?
Re: Spree clutch
Posted: Sun Jun 20, 2010 8:22 am
by tha juggalo boss
good plan-i was wondering about the ammount of accuracy needed to customize a set of stock clutch springs with out compramiseing their ability to function properly-I didnt think I could get them close enough to the same tention and figured i would wind up with a different ammount of wear on each of the clutch arm pads not to mention wearing them out quickly and possibly ruining the bearings in the transmition case- but it worked for you- I guess i over thought it a bit!!
Re: Spree clutch
Posted: Mon Jun 21, 2010 7:54 pm
by tha juggalo boss
Trafficjamz wrote:tha juggalo boss wrote:@Traffic Jamz- your comment about the springs on the spree clutch- in your reply to my question about the clutch mod got me thinking as well- we may be thinking along the same lines- let me know what you come up with!
Will post photos soon!!
Re: Spree clutch
Posted: Mon Jun 21, 2010 9:26 pm
by ae86guy
ill post a pic of the clutch with new springs in it tomorrow i dont think the springs i modded r all exactly the same tension but they are pretty close i havent had any problems with them and they are heaps better than standard ones
Re: Spree clutch
Posted: Mon Jun 21, 2010 9:36 pm
by tha juggalo boss
ae86guy wrote:ill post a pic of the clutch with new springs in it tomorrow i dont think the springs i modded r all exactly the same tension but they are pretty close i havent had any problems with them and they are haeps better than standard ones
deffinatly let me know how much they have worn or if they are worn differently from one to the next!!! if they arent showing any signs I will probably attempt it!!! thanks for being willing to tear it appart just for some photos!!
Re: Spree clutch
Posted: Thu Jun 24, 2010 4:10 am
by ae86guy
Re: Spree clutch
Posted: Thu Jun 24, 2010 10:11 pm
by ae86guy
Re: Spree clutch
Posted: Sun Jun 27, 2010 9:35 am
by tha juggalo boss
photos of two arm clutch and three arm clutch-
Re: Spree clutch
Posted: Sun Jun 27, 2010 9:37 am
by tha juggalo boss
another photo
Re: Spree clutch
Posted: Sat Jul 10, 2010 10:52 pm
by yamahauler660r
So, what's that 2 arm from?
