carb main bolts
edwardzx7
carb main bolts
Post by edwardzx7 »
anyone know the size and lenth of the 2 main carb bolts that hold the carb on?not the ones that go on the pulley part,but the main part that just like floats there.4 carb bolts total.only need 2.
Image-$show your right$
Couple of ways to do this (you must be working on an Elite, Spree have 2:)
1) Use a toothpick/paperclip/wire, run this down the hole and measure the length with the carb intake in place. Use a slightly shorter fastener for that hole.
2) Go to partsfish.com and look up the bolts there, if you select them it lists the length, in millimeters.
Have fun.
Admin, Hondaspree.net
edwardzx7
Post by edwardzx7 »
thanks but does not help any!
uspmale
Post by uspmale »
Edd, If you can send a pic. with a reference scale, I'LL be able to help.
Or be more specific. on the part.
I have literally thousands of Spree parts from A to Z.
Thanks, Greg
uspmale@yahoo.com
edwardzx7
Post by edwardzx7 »
,this should help,Image
uspmale
Post by uspmale »
It looks like you need 2 carb bolts,right?
I've got several dozen. E-mail me cause they're 2 different sizes.
uspmale@ yahoo.com
lonelywanderer
Post by lonelywanderer »
if you need the two that bolt the carb to the manifold its 6x1.00 mm
hrnytrtlsgsxr
Post by hrnytrtlsgsxr »
lonelywanderer wrote:if you need the two that bolt the carb to the manifold its 6x1.00 mm
that sounds right
lonelywanderer
that sounds right
:D
