Spree boggin at speed
CHEVY-212010
Post by CHEVY-212010 »
Spree is doin good except when i hit "25 mph". Its revving up real good up until then and then it just looses powah and boggs out. I have played around with the carb, seeing if it is a tuning issue, but i cannot find out what is wrong.
Thank you all for your help.
MIke
'85 Spree NQ57
'81 CT70
'99 GMC Sierra
'53 Chevy 3100
Re: Spree boggin at speed
Is the air box, air filter and air box lid on and everything sealed properly becuase ths sounds like a lean condition.
CHEVY-212010
http://www.sears.com/shc/s/p_10153_1260 ... blockType=
This is the air filter attached to the tube from the carb to the box.
I have the 44mm bbk kit on it
There is a #74 main in the carb
'85 Spree NQ57
'81 CT70
'99 GMC Sierra
'53 Chevy 3100
CHEVY-212010 wrote:http://www.sears.com/shc/s/p_10153_1260 ... blockType=
put in a bigger jet or tape up 90% of that filter.
CHEVY-212010
ok ill try the tape and i think i have a larger jet i can try
thanks
MIke
'85 Spree NQ57
'81 CT70
'99 GMC Sierra
'53 Chevy 3100
ae86guy
Post by ae86guy »
you should have got a 85 jet with the kit if its from taz im running a 88 jet and a k&n pod filter in a custom adjustable air box with just the k&n bolted to the carb mine bogged down when approching wot then had to back off to get more speed i think more tuning is needed on your spree do plug chops see what colour the plug is
CHEVY-212010
i got a #95 with my kit, but im goin to try out an 80 something i have laying around, I did however tape up about half of my intake and it did cruse up to "30" :geekdance: Thanks for the advice ae86guy, you saved me from making another thread.
MIke
'85 Spree NQ57
'81 CT70
'99 GMC Sierra
'53 Chevy 3100
CHEVY-212010
Replaced the main with a #84 i had and it solved the problem, can now reach the 35 mark on the speedo, but a new thing is happening. When i try to exceed that mark it backfires and looses power.
thoughts or suggestions...
thanks :hi:
MIke
'85 Spree NQ57
'81 CT70
'99 GMC Sierra
'53 Chevy 3100
Upshifter
Post by Upshifter »
It may be an overly simplified answer, but I would make perfectly sure that the gas cap vent is not plugged up a little. If the vent becomes plugged, it won't allow the fuel to flow enough, and the engine will often run lean, and show all sorts of weird symptoms.
"If you can defeat the enemy within,
the enemy without can do you no harm."
ae86guy
Post by ae86guy »
or now that you are allowing the motor to rev to its full potential you will propbably find its four stokeing at top rpm i would check the plug after a good wot run see if its leaning out if not then as far as i know it should be ok just when you start to four stroke just back off the throttle a bit your motor its kinda sounds like a rev limiter in a car get a tach and see what revs your pulling ill bet its high please someone correct me if im wrong
PimpinSpree
Post by PimpinSpree »
id put a bigger jet in. Check you spark plug, i bet it looks really white on the tip
