Expander rings
Posted: Tue Dec 20, 2005 3:35 am
by niftyfifty
just went down to local honda dealer and ordered new rings, boys in workshop said " do u have expander rings for it", i said yeah for the bottom ring, he said dont put it back on when you replace the rings, they cause more problems than they are worth. i said whys that, he said excessive rings wear and they can score the * out of you bore.
so now i'm thinking do i put them back on or leave it>??? whats your response,
Posted: Tue Dec 20, 2005 6:11 am
by darat
wont alot of compresson blow by because of that tho?
Posted: Tue Dec 20, 2005 12:07 pm
by burnt_toast
expander rings?
Posted: Tue Dec 20, 2005 6:52 pm
by vette76
the black spring like piece between the bottom ring, and the piston. i would put it in, since it expands the ring. its there for a reason.
Posted: Wed Dec 21, 2005 2:04 am
by niftyfifty
yeah thanks guys, will do and plus if i didnt what would really be the point of putting bottom rings in, cos they would stick out enough
Posted: Wed Dec 21, 2005 9:42 am
by burnt_toast
in this picture is the very innermost ring the expander ring? I've seen one of those w/ every ring set I worked with but never used it.
Posted: Wed Dec 21, 2005 11:31 am
by vette76
yes. that is the expander ring.
Posted: Wed Dec 21, 2005 7:06 pm
by MySpree
got one on my scoots top and bottom.
Posted: Wed Dec 21, 2005 9:30 pm
by maddog
I never use them.
Posted: Wed Dec 21, 2005 10:31 pm
by MySpree
i always use em. it tells me to in the manual
Posted: Thu Dec 22, 2005 12:56 am
by burnt_toast
maddog wrote:I never use them.
werd. they look like they could do some serious damage if they dont stay in there just right.
Posted: Thu Dec 22, 2005 8:23 am
by vette76
ive never had a problem. they seem to stay in there pretty good.
Posted: Tue Dec 27, 2005 6:42 pm
by niftyfifty
this issue is least on my mind now!
as i was putting the rings on the piston, and putting the piston on to the crank, i slid the guiden pin into its hole, i had a clothe securing the crankhousing so the little pins would fall down into the crank housing, i did one side fine, wen to do the other, the pin popped out of my pliers and fell through the small gap in the clothe down into the crank housing! i have taken the engine out and tried shaking it out, but i cant hear anything!
what i do? do i need to take the whole crankhousing out? help!!!
Posted: Wed Dec 28, 2005 12:42 am
by burnt_toast
niftyfifty wrote:this issue is least on my mind now!
u took the whole engine out? as in case out of swingarm?
I had something similar happen when a piece of the stock piston broke off and fell down in there, siezed my crank to only move a certain rotation. I dumped all liquids and flipped it upside down and played with the crank while shaking it and eventually the piece(s) fell out and i had this same crank work for the entire time i rode the spree.
try that and see what happens.
Posted: Wed Dec 28, 2005 5:01 pm
by niftyfifty
yeah it took the whole engine out, iv been shaken and stuff i really cant get it out, must be all that oil i guess, the boys on another post have told me to spray some carb cleaner in there. so il give that a go.
im going to be real angry if its not even in there!
