Quick replacement for a throttle pin retainer?
coolgangsta24
Post by coolgangsta24 »
I took apart my throttle assembly on my '86 Spree that I rebuilt last year and the retainer spring flew somewhere into my front lawn. They still sell the part but only as part of a set with the pin and little c-clip, and I don't want to shell out $20 for it.
Anybody have any ideas on what I can replace it with?
-Thanks in advance
Re: Quick replacement for a throttle pin retainer?
Yeah, don't loose the little parts. :eyeroll:
Here's a pic that may help. The clip is about 0.012 thick, and fills the slot pretty well. The needle is 0.080. You can do some pixel work comparing the shaft to slot thickness and come up with an exact figure. Totally off the cuff, a guess is a 1/16" e clip (maybe 1.5mm is better). But the thickness is going to be a factor. Someone here may have a spare clip for you, that would be the easy route...
Good luck - and I've been there with clips and other parts that spring off into far corners of the shop or work area.
fightingplankton
Post by fightingplankton »
i actually think i have a spare.. let me go check and i'll get back to you.
'86 spree
'86 aero50
'83 aero80
fightingplankton
yes i do have one. its from an '85 spree. assuming there is no difference between years...its yours for the asking.
'86 spree
'86 aero50
'83 aero80
coolgangsta24
Oops, sorry to confuse everyone. I'm not talking about the little c or e-clip but rather the thing shaped like a "W" that sits on top of it between the c-clip and the spring.
Thanks for all the help and offers so far though!
fightingplankton
i actually have that whole assembly if you want it. its part "2" on the carb microfiche.
i'll just send the whole needle, retainer, c-clip in an envelope just in case you lose anything else...i dont even have a spree anymore. pm me your addy
'86 spree
'86 aero50
'83 aero80
drizzle
Post by drizzle »
be sure to wrap up those pointy bits real good.... the PO of our razz tried sending the key to us in the mail in an envelope... tore the envelope and fell out in shipping and now it's lost forever.
