Quick replacement for a throttle pin retainer?
Posted: Sat Jul 03, 2010 10:22 pm
by coolgangsta24
I took apart my throttle assembly on my '86 Spree that I rebuilt last year and the retainer spring flew somewhere into my front lawn. They still sell the part but only as part of a set with the pin and little c-clip, and I don't want to shell out $20 for it.
Anybody have any ideas on what I can replace it with?
-Thanks in advance
Re: Quick replacement for a throttle pin retainer?
Posted: Sun Jul 04, 2010 12:08 am
Yeah, don't loose the little parts. :eyeroll:
Posted: Sun Jul 04, 2010 1:19 am
Here's a pic that may help. The clip is about 0.012 thick, and fills the slot pretty well. The needle is 0.080. You can do some pixel work comparing the shaft to slot thickness and come up with an exact figure. Totally off the cuff, a guess is a 1/16" e clip (maybe 1.5mm is better). But the thickness is going to be a factor. Someone here may have a spare clip for you, that would be the easy route...
Good luck - and I've been there with clips and other parts that spring off into far corners of the shop or work area.
Posted: Sun Jul 04, 2010 10:40 am
by fightingplankton
i actually think i have a spare.. let me go check and i'll get back to you.
Posted: Sun Jul 04, 2010 10:47 am
by fightingplankton
yes i do have one. its from an '85 spree. assuming there is no difference between years...its yours for the asking.
Posted: Mon Jul 05, 2010 12:22 am
by coolgangsta24
Oops, sorry to confuse everyone. I'm not talking about the little c or e-clip but rather the thing shaped like a "W" that sits on top of it between the c-clip and the spring.
Thanks for all the help and offers so far though!
Posted: Mon Jul 05, 2010 1:24 am
by fightingplankton
i actually have that whole assembly if you want it. its part "2" on the carb microfiche.
i'll just send the whole needle, retainer, c-clip in an envelope just in case you lose anything else...i dont even have a spree anymore. pm me your addy
Posted: Mon Jul 05, 2010 2:20 am
by drizzle
be sure to wrap up those pointy bits real good.... the PO of our razz tried sending the key to us in the mail in an envelope... tore the envelope and fell out in shipping and now it's lost forever.
