Premix ratio?
Mirage
Premix ratio?
Post by Mirage »
Hi, so i bought a scooter and all the oil lines have been removed and blocked up. So im guessing it runs premix? how do i check and what is the oil to gas ratio? (how much oil per full tank?) cheers.
Also headlight doesnt work, tried different bulbs too.
Re: Premix ratio?
If you run 50 to 1 with a stock motor you will be fine and not smoke to much. If you are hot rodded, 32 to 1 would be safer. The head light is driven AC voltage from the alternator and is only on when the engine is running.
