Engine/piston work part 2
dbouchard01
Post by dbouchard01 »
Okay I have replaced the Piston and rings and now I have compression but it still will not fire. I have spark and gas so anyone have any ideas?
sanjuro
Re: Engine/piston work part 2
Post by sanjuro »
Loose ignition coil or wires?
dbouchard01
I double checked those while putting back together. Will not start using ignition switch or kick start.
maddog
Post by maddog »
it will take 20-30 kicks to fill the case, hint put yur hand over the back of the carb while cranking.
bradthreee
Post by bradthreee »
Press brake lever
Turn kill switch to On position...
bradthreee wrote:Press brake lever
If he has spark it can't be that.
maddog
Post by maddog »
HA ! :bump: HA ! :bump:
