Custom Wheels
Custom Wheels
Where do you all get your alloy or custom wheels?
- Trafficjamz
Re: Custom Wheels
ebayC3Killer wrote:Where do you all get your alloy or custom wheels?
Re: Custom Wheels
What do ya'll search for? Whats compatible?
- Trafficjamz
Re: Custom Wheels
honda dio rimC3Killer wrote:What do ya'll search for? Whats compatible?
http://cgi.ebay.com/ebaymotors/Honda-DI ... ccessories
The rear wheel is a direct fit. The front wheel can be made to work with mods.
Re: Custom Wheels
what kinda mods are you talking? and what if you want to use the stock drum brake?
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
- Trafficjamz
Re: Custom Wheels
not 100% sure what all need to be doneodinxxix wrote:what kinda mods are you talking? and what if you want to use the stock drum brake?
something about 12mm axle bolt vs 10mm
That front wheel is made to fit a japan dio or a U.S. ruckus
- bradthreee
Re: Custom Wheels
if anybody here has done it or knows what this intails that i would like to know. id like to get a set or wheels that look different then stock honda.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
- Trafficjamz
Re: Custom Wheels
front drum = 110mm
front bearing axle is 12mm
So you would have to mod the 10mm bushing to 12mm, and find a 110mm brake assembly.
What other honda scooter has a 110mm front drum brake?
Re: Custom Wheels
Bumping this - Not sure you are right, Trafficjamz -
the bearings used, according to PowerSportsPlus, are 6200U - they have a 10mm inner diameter.
I purchased the 6200-2RS bearings for my new front wheel, they are 10mm and are sealed unlike the stock bearings.
Here is a good reference:
http://www.pibsales.com/pdf/6200.pdf
- sum-azn-kid
Re: Custom Wheels
What kind of bike is it for? there are disk brake rims/ drum. the 12mm is for sym/taiwan bikes mostly and 10mm is japan ruckus/elite. do you want to swap you front end? there is alot of options.
zuma 125-sold
Ninja 250r-totaled
zuma 125-sold
Ninja 250r-totaled
- Trafficjamz
Re: Custom Wheels
knucks wrote:Bumping this - Not sure you are right, Trafficjamz -
I was not talking about stock rims. I was referring to 12mm axle size of the wheels in the ebay link, that has expired long ago.
Re: Custom Wheels
I have a connection for Dio style wheels with front disc. Cheap cheap!
elite_dub wrote:As for you phatkix you speak as you please, I know you can't play with the big boys.
Re: Custom Wheels
Where in canada are you located?
Re: Custom Wheels
B.C.
