Build "X" starts
Fishman43
Build "X" starts
Post by Fishman43 »
This build is just going to be called "X" for now until a final name is picked. Day one consisted of pulling apart the stock Dio motor, getting the new 9.1 gear pressed on and the final drive back together. Then putting the new 1500 center spring on with the new prodigy clutch and vented bell.
Fishman43
Re: Build "X" starts
Post by Fishman43 »
Hee, hee, hee, stock piston with new Nikasil piston and bore :2thumbs:
sum-azn-kid
Post by sum-azn-kid »
what pipe are you going to use with the 78cc?
zuma 125-sold
Ninja 250r-totaled
Congrats on the X assembly. May I suggest you reconsider the choice of 9:1 gears, however? Those may prove to be a bit short. With the right pipe you may reach 55 or more but that will occur after the Vario maxes and at a very high RPM.
8.4:1 will leave some variator function in reserve. Sorry this comes a bit late...
Fishman43
Post by Fishman43 »
I am using the same pipe as the one on this scoot, procured from Wheelman.
808BMW wrote:Image
I put some thought into the 9:1 gears vs a taller ratio, but my local roads are all 25-45 mph. There is only one 55mph road around and it is semi truck central. I don't want to be a hood ornament, so won't be using said road. If the 9:1 gears seem to short after break in it isn't all that hard to switch them out later.
Fishman43
Post by Fishman43 »
Did some plastic crack repairs today.
fightingplankton
Post by fightingplankton »
just want to make sure...
matthew broderick wont have anything to do w/ this "project x" will he? he totally F***ed the last one over
'86 spree
'86 aero50
'83 aero80
Fishman43
Post by Fishman43 »
Ha, ha, ha
Chicago Ben
Post by Chicago Ben »
Fishman43 wrote:Did some plastic crack repairs today.
hey, can you explain to me the process you are doing here... i need to do this on some cracks on my panels as well
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Fishman43
Post by Fishman43 »
Sand back side of plastic where patch will go. Cut patch of fiber glass to fit (I use woven), apply liberal amount of all purpose PVC glue, apply fiberglass into glue, add more if needed to wet fiber glass (shouldn't need to enough should have been done in step two). Clamp into corect shape if needed, wait for it to dry.
bradthreee
Post by bradthreee »
Fishman43 wrote:Ha, ha, ha
I absolutely loved that movie :love:
Nice work so far Fish :thumbsup:
sum-azn-kid
how does that pipe perform/sound one of my friends had it but sold it before he even used.
zuma 125-sold
Ninja 250r-totaled
burnt_toast
Post by burnt_toast »
9:1 gears are perfect for your speed goals, and can easily cruise 45-50mph w/out strain, top speed near 60mph shee boogie :thumbsup:
projects galore :nerd:
Fishman43
Post by Fishman43 »
Sha-weet. Mayby I will actually get some more work done on it soon :werd:
fightingplankton
i want photo updates...
bump
'86 spree
'86 aero50
'83 aero80
