possable clutch swap?
Posted: Sun Jul 11, 2010 3:05 am
by tha juggalo boss
im wondering if swapping the three arm clutch in my spree to an elite e clutch(same diameter) with two clutch arms would make any difference? or at least using the two arm clutch to expariment with the spring tention???? im thinking if i shorten the springs a little to make the clutch enguage at a higher rpm like ae86guy suggested, the two arm clutch would enguage a little better and mabe even a little quicker because the pads are much larger allowing for more of the pad surface to grip the bell housing, and also less chance of slipage- I know you guys put a lot of time and thought into your projects so i figure someone has probably tried it or can tell me why I shouldent-or should- thanks for any input!!
Re: possable clutch swap?
Posted: Sun Jul 11, 2010 3:08 am
by tha juggalo boss
spree clutch is on right, elite e clutch is on the left-
Posted: Sun Jul 11, 2010 5:15 pm
by Trafficjamz
I have done this swap. A lot less slippage.
Posted: Mon Jul 19, 2010 12:38 am
by eliteguy50
Trafficjamz wrote:I have done this swap. A lot less slippage.
Stock for stock or with the springs too? Thinking about just swapping the entire driven assembly...
Posted: Mon Jul 19, 2010 12:44 am
by Trafficjamz
eliteguy50 wrote:Trafficjamz wrote:I have done this swap. A lot less slippage.
With or without the aftermarket springs, this is a good swap.
The two puck design just has more suface area.
