Trail Tech Vapor CHT problem
da808nanospeed
Post by da808nanospeed »
got my Vapor install for couple weeks, works out fine, but I notice my cht always fluctuate when i was riding my scooter. the temp goes from 330 then drop to 230 then come back up, then eventually it quit and display no temp. I have to press the reset button then the temp will show again. did anyone encounter this problem with the vapor?
2003 Yamaha R1 998cc SOLD
1997 Honda Elite S 72cc SOLD
2007 SYM DD50 72CC X2
Goped sport 29cc
Re: Trail Tech Vapor CHT problem
da808nanospeed wrote:got my Vapor install for couple weeks, works out fine, but I notice my cht always fluctuate when i was riding my scooter. the temp goes from 330 then drop to 230 then come back up, then eventually it quit and display no temp. I have to press the reset button then the temp will show again. did anyone encounter this problem with the vapor?
Sounds like you have a faulty unit. Call Trail Tech's customer service and ask them is your best better.
tw39515
Post by tw39515 »
my temps fluctuate too but corresponds to opening and shutting the throttle. twice this weekend i had to reset it to get it to respond.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
da808nanospeed
do you think is due to i extended the cht sensor wire, but i soldered wire, it shouldn't have any lost connection
Goped sport 29cc
tw39515
Post by tw39515 »
i bought the extension and it still happened.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
bakaracer
Post by bakaracer »
do you guys have the power wire hooked up or just running off the battery in the gauge?
tw39515
Post by tw39515 »
power hooked up to ignition here.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
da808nanospeed
tw39515 wrote:power hooked up to ignition here.
same here
Goped sport 29cc
bakaracer
Post by bakaracer »
so you have it hooked up where when you turn on the key,the back light comes on? try taking the battery out of the gauge and put it back in.I have 2 of those gauges and haven't had any issues like you guys are having nd I had my gauges for over 2 years. double check all your wire hook ups. double check the ground wire hookup too.
da808nanospeed
bakaracer wrote:so you have it hooked up where when you turn on the key,the back light comes on? try taking the battery out of the gauge and put it back in.I have 2 of those gauges and haven't had any issues like you guys are having nd I had my gauges for over 2 years. double check all your wire hook ups. double check the ground wire hookup too.
I got the 48" extension and a new sensor. Now my Temp doesn't fluctuate anymore, works good
Goped sport 29cc
bakaracer
Post by bakaracer »
did you get it from trailtech? did you have to pay?
da808nanospeed
bakaracer wrote:did you get it from trailtech? did you have to pay?
I just email their tech support, the just send a new CHT sensor for free, then i request for a 48" extension, they also send it to me for free.
Goped sport 29cc
vette66_00
Post by vette66_00 »
I have also had this same problem with the Vapor. Sporadic Temp sensor readings. Called Trail Tech yesterday told me to do a couple things, found out that the extension wire has a bad connection. They sent me out a new one after I got off the phone with them.. For a $100+ item there customer service is awesome willing to sit on the phone with you while you check measurements and test. I will be buying another one from them when it comes time.
89 Honda Elite E 48cc bbk and gears all broken in... I get to 35 mph (gps) full out and Im 240 lbs. Need more speed
My toy.. http://www.youtube.com/watch?v=LWgZXLUy25U
tw39515
Post by tw39515 »
just got around to figuring out my problem. its a bad sensor too. i bought a trail tech tto, so had some parts to do troubleshooting. ill see what trailtechs gonna do bout sending out a new sensor.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
Mine does that once in a while too. :confused: (blank CHT)
Has any one figured this out 100%
