Honda Spree: Lost some top end power.
IMiteBeWrong
Post by IMiteBeWrong »
So recently I was making my way home from work. It's about a 10 mile straight strip of road. I usually go about 30 - 35mph consistently the whole way. When I was about a mile from home all the sudden bam, my spree putters out and dies. I walked to a parking lot and managed to get it started again.
Now heres my problem:
-since the incident I now can only travel at 25mph maybe 30 down a hill. Also the top end power just isn't the same. A little hesitation when it gets near 27, like its being restricted.
heres the steps I've taken:
-I swapped the carb out with an extra one I have, no change.
-I checked thoroughly for airbox leaks and cant find anything.
-checked the air filter, its clean and oiled.
-changed the spark plug and made sure gap was correct.
-swapped out the CDI for an extra one I had.
-added seafoam to gas tank and a little to the oil tank.
Side note: The day this happened I topped off my gas tank and premixed with some 2 cycle oil. Got distracted by something and dumped more in than I normally do. (nice set of * walking by)
Could have I put too much oil into the gas and caused the lingering issue?
I siphoned all the gas out when i got home and replaced it with fresh gas with seafoam in it. Would it just take a while to clean itself out??
I have noticed some small improvements after a tank of fresh gas with seafoam.
sorry for the long post, I'm just really scratching my head with this one!
86' green/white Spree NQ50
85' red Spree NQ50
Re: Honda Spree: Lost some top end power.
Check head bolts for tightness
Check compression.
fightingplankton
Post by fightingplankton »
i'm not saying its why your bike died...in fact, i'm saying it's probably not.
but... if you belt wears too thin, the pulleys cant grip it as well so, after a while, you'll see a bit of loss...from what i understand, this is gradual though.
'86 spree
'86 aero50
'83 aero80
I'm with TJ, check compression first on this kind of deal.
IMiteBeWrong
Forgot to say, I did find the culprit here:
The threads on the carb, where it attaches to the engine, were stripped out on both of the carbs I tried.The carb wasnt tight enough against the engine opening, thus I had a big ugly vaccum leak giving me all my headaches.
Solved my problem by using 1/4-20 instead of the 6mm standard bolts. Fit in there nice and tight.
Just wanted to add a possible fix to the list of possible issues others may have in the future. :)
85' red Spree NQ50
GJbean
Post by GJbean »
IMiteBeWrong wrote:Forgot to say, I did find the culprit here:
hmmm gonna try this on my elite. thanks.
GJbean
Post by GJbean »
darn, tightened the bolts last night and no change.
