NEW DIAL-IN MAIN JET
uspmale
Post by uspmale »
Below is pictured a Spree carb with a real dial-in main jet.
After several months of trial and error, the persistence paid off.
The main jet is drilled oversized then adaptions made to accept the new needle with a good range of adjustments.
The only problem now is after 4-5 adjustments the o-ring leaks slightly.
This is due to the needle threads cutting in after 4-5 adjustments.
A new o-ring cost about $.30 so I've been changing it out till I got the ideal 12-1 air fuel ratio, then it will seal once the setting is final.
After bench testing this week, it runs real sweeeet! It never ran like this ever before!
Using a ported intake and adjusting the timing, with a cone air filter, this Spree sounds like it doesn't want to quit. Better throttle response and no bogging at high rpm.
Waiting for better weather to road test. Hope this snow goes away soon.
You can click to enlarge image.
This is a pro-type for viewing only. But you should be able to see the concept.
maddog
Post by maddog »
What is it that you guys want! the spree was the worst moped that came from honda! even an express can blow it away.
burnt_toast
Post by burnt_toast »
maddog wrote:What is it that you guys want! the spree was the worst moped that came from honda! even an express can blow it away.
that was an unnecessary comment. :?
pretty cool with the dial-in jet. Also good that you actually have a cone filter working w/ that.
projects galore :nerd:
darat
Post by darat »
WOW ur on a spree website and ur talkin bad about them shame on u
burnt_toast
darat wrote:WOW ur on a spree website and ur talkin bad about them shame on u
yeh seriously.
He's shipped me one of these to run with the new pipe/piston that Maddog sent me. Once the weather warms up I'm going to write a review up of it.
Admin, Hondaspree.net
darat
Post by darat »
wait they make a new piston for the spree?
I've got a 2mm over piston, 43mm diam.
