Won't start, no fuel in the carb
Posted: Tue Jul 20, 2010 10:45 am
by a9110108
Replaced throttle cable. Now won't start. No fuel in the carb (bowl) after cranking. How do I get fuel to the carb?
Re: Won't start, no fuel in the carb
Posted: Tue Jul 20, 2010 11:03 am
by toad772
a9110108 wrote:Replaced throttle cable. Now won't start. No fuel in the carb (bowl) after cranking. How do I get fuel to the carb?
Take the carb off and take it apart and clean it out check fuel lines for clogs put carb back on hook it up and see if it is fixed
by fightingplankton
after taking my carb off for cleaning, i always prime it by sucking on the lower hose from the petcock to create vacuum to let the fuel flow into the carb...thats just me though.
Posted: Tue Jul 20, 2010 11:04 am
by toad772
actually check the fuel lines first
Posted: Tue Jul 20, 2010 11:05 am
by toad772
fightingplankton wrote:after taking my carb off for cleaning, i always prime it by sucking on the lower hose from the petcock to create vacuum to let the fuel flow into the carb...thats just me though.
yeah doing that might be a good idea my petcock is screwed so fuel flows all the time so I don't have to.
Posted: Tue Jul 20, 2010 11:55 am
The first question no one asked, is the fuel in the fuel line? If not either the petcock is screwed of the screen in the tank is plugged or the tank is empty. Screwing with the carb until you prove there is fuel in the line shows a lack of logic and troubleshooting skills.
If there is fuel in the fuel ine, then check the needle and seat in the carb.
Posted: Tue Jul 20, 2010 1:09 pm
by toad772
Bear45-70 wrote:The first question no one asked, is the fuel in the fuel line? If not either the petcock is screwed of the screen in the tank is plugged or the tank is empty. Screwing with the carb until you prove there is fuel in the line shows a lack of logic and troubleshooting skills.
My second post said "actually check the fuel lines first"
Posted: Tue Jul 20, 2010 6:53 pm
by a9110108
Fuel lines are dry. They are not clogged. Fuel is in tank. Visibly checked screens in tank and they did not appear to be blocked. How would I check the petcock? Should I just buy another one?
I'll try sucking on the lines...that should be fun!
Posted: Tue Jul 20, 2010 7:08 pm
by martynkim
No need to suck on the lines to prime. Just place your hand over the opening of the carb and if all is working correct, it will pull gas in to it.
Posted: Tue Jul 20, 2010 9:02 pm
martynkim wrote:No need to suck on the lines to prime. Just place your hand over the opening of the carb and if all is working correct, it will pull gas in to it.
With no fuel in the carb or the fuel line, hand over anything is not gonna prime anything because there has to be fuel in the carb for the hand choke trick to work on.
Your petcock is frozen closed, allowing no fuel to reach the carb. Either work it over and get it open or replace it.
You only suck on the line from the intake manifold up to the bottom of the petcock. It is the vacuum line that is suppose to open the petcock.
Posted: Tue Jul 20, 2010 9:34 pm
by Saved
Make sure you didn't mix the fuel and vac lines up. I did this once. It wasn't fun.
Posted: Tue Jul 20, 2010 9:39 pm
by martynkim
Bear45-70 wrote:martynkim wrote:No need to suck on the lines to prime. Just place your hand over the opening of the carb and if all is working correct, it will pull gas in to it.
This is why I said if all is working correct.
Posted: Tue Jul 20, 2010 9:46 pm
I suggest you remove and pour out the fuel tank. Then remove the petcock and see if an overnight in NAPA carb dunk will resurrect it. I've gotten a couple to work this way, along with patient poking with sharp Wheel-stick. Some people say the NAPA carb dunk will ruin the diaphragm. I say:
1. Those people are incorrect.
2. It already ain't workin', so whaddya got to lose?
Posted: Tue Jul 20, 2010 11:29 pm
by fightingplankton
has anyone suggested the in-tank fuel filter yet?
Posted: Wed Jul 21, 2010 8:03 pm
by bradthreee
Wheelman-111 wrote:Greetings:
I've also used WD-40 to clean out petcocks. Its worked great and saved the rubber diaphram from melting away.
If you must suck on those lines, make sure you suck on the one that on the lowest position of the petcock. And whatever you do dont blow into the gas line unless you like a mouthful of gas
Dont ask me how I know
